Old Apr 29, 2014, 10:21 AM
Mrloseth's Avatar
Joined Jan 2013
Help!
Q80-8m question
I'm looking for and gather information about many of you use the Q80-8m and if you have noticed if you have a lot of play in the motor bearings on this hacker type?
and that you have the opportunity and push the motor in and out?
Mrloseth is offline Find More Posts by Mrloseth
Old Apr 29, 2014, 11:49 AM
The Earth got in the way!
kuczy's Avatar
United States, OH, Canal Winchester
Joined Feb 2007
My motor does not push in or out. It only has 6 flights on it though.
kuczy is offline Find More Posts by kuczy
Latest blog entry: 3DHS 92" Edge
Old Apr 29, 2014, 02:30 PM
Mrloseth's Avatar
Joined Jan 2013
After 5 flight mine got play :-/ yours got nothing?
Old Apr 29, 2014, 02:35 PM
kuczy's Avatar
Joined Feb 2007
Just checked again. Mine is solid. No play at all
Old Apr 29, 2014, 02:44 PM
Team 3DHS
joesmith285's Avatar
United States, IN, Fort Wayne
Joined Nov 2008
All of mine have a little play in and out. Going on the third flying season with them like that. Not sure it's anything to be worried about.....
joesmith285 is online now Find More Posts by joesmith285
Old Apr 29, 2014, 03:17 PM
kuczy's Avatar
Joined Feb 2007
I guess mine will develop some play over time then..
Old Apr 30, 2014, 05:03 AM
Mrloseth's Avatar
Joined Jan 2013
Joe does your's got play when you shake the end off the propp if you noe what i mean? :-)
Old Apr 30, 2014, 08:12 AM
EXTREME FLIGHT's Avatar
United States, GA, Cumming
Joined Feb 2004
Check to make sure the big socket head cap screw on the rear of the motor is tight. Mine came loose and the motor was beginning to pull apart.
EXTREME FLIGHT is offline Find More Posts by EXTREME FLIGHT
Site Sponsor
Old Apr 30, 2014, 09:14 AM
Team 3DHS
Joined Nov 2008
I have 3 of them and they all push in and pull out a very small amount. You can feel that by pushing in and out on the tip of the prop.
Like Chris said above, just make sure the big bolt is tight, as it is basically what holds the motor together. If this is tight, I don't think you have anything to worry about.
Old Apr 30, 2014, 12:11 PM
Mrloseth's Avatar
Joined Jan 2013
Q80-8m question
Every bolt is tight'n :-)
So then i just can say that this is normal, because i have now asked 6 people and every one have play, my a60-6xs has none, but maybe this hacker is built diffrent.
Help! Q80-8m question Mrloseth Power Systems 1 Apr 29, 2014 09:46 AM
Discussion Hacker Q80-8M vs Motrolfly 5335 huvaljohn Electric Plane Talk 1 Mar 14, 2014 10:42 AM
Wanted Hacker Q80-8M/ESC huvaljohn Aircraft - Electric - Power Systems (FS/W) 1 Mar 10, 2014 07:37 PM
Idea Hitec 7955tg 89"slick q80-8m Mrloseth 3D Flying 6 Feb 25, 2014 08:56 PM
Sold Hacker q80-8m ice160HV and extras $775 shipped CONUS joshet89 Aircraft - Electric - Power Systems (FS/W) 0 Oct 26, 2013 11:29 AM
