Old Sep 15, 2013, 04:04 AM
United Kingdom, England, Nottingham
Joined Aug 2012
Help!
Arx bike help
hi guys need your help again with my arx dirt bike when I got my bike off some one the rear drive shaft was broken so now I have replaced it with a new one put it all back together using the manual using new wheel bearing etc etc put the to spacers on the ends b4 I put it back on the swing arm but its doing my head in now because when it tighten up the nut it making the wheel turn stiff but if I undo the nut it turns ok I must have stripped the wheel down over 8 time to see whats wrong
walters1973 is offline Find More Posts by walters1973
Old Sep 15, 2013, 07:09 AM
United Kingdom, Walsall
Joined Mar 2013
If you've definitely got the spacer washers in place between the wheel and the swing arm it sounds like one of the spacers inside the wheel is missing or slightly too thin causing binding. You say you've replace the bearings, maybe one isn't quite the correct size?
Syncro is online now Find More Posts by Syncro
Old Sep 15, 2013, 09:06 AM
Joined Aug 2012
yes mate got the to washers on it was doing it with the old bearing so it not that
Discussion ARX-540 questions and help Samicidal Motorcycles 1 Feb 10, 2013 12:17 AM
Discussion New Off-road bike ARx-540 winniethepooh Canada 1 Oct 20, 2007 12:47 PM
Discussion New Off Road bike 1:4 ARx-540 winniethepooh New Zealand 0 Sep 26, 2007 07:36 AM
Discussion New offr road bike ARx-540 1:4 scale winniethepooh Denmark 0 Sep 26, 2007 07:35 AM
Discussion New Off Road bike 1:4 ARx-540 winniethepooh France 0 Sep 26, 2007 06:47 AM
