Old Oct 29, 2013, 06:08 PM
Isaiah 40:31
Clickety's Avatar
United Kingdom, England, Hamble-le-Rice
Joined Sep 2012
Updates
Work in progress 'upgrades' to the model. I've decided to re-cycle the canopy from the prototype. With the clear canopy, It is easier to get the canopy shape correct to suit the depron. When I created the vac forming tool It was best estimate.
The plastic canopy on here is a bit of a work-in-progress with silver marker pen on it to help me highlight the final shape. It will look much better a little further down the line.....
Clickety is offline Find More Posts by Clickety
Old Oct 30, 2013, 10:53 AM
Isaiah 40:31
Clickety's Avatar
Joined Sep 2012
This morning I applied some 0.6oz Super light fibreglass cloth to the underside of the nose and the belly around the intakes with water based Polyurethane varnish (matt). It was an experiment to test how much weight it added vs its usefulness as a depron protector.
Weight current 560g. I was a little shocked that it added 27g. I guess I was a bit heavy handed handed with the resin
it is however rock hard! and it has visually disappeared! I think this will be quite a useful thing to do on the EDF version, which needs to fly in with a bit of speed.
In hindsight, I would be a little more reserved with the resin.... next time!
Old Oct 31, 2013, 03:58 AM
Isaiah 40:31
Clickety's Avatar
Joined Sep 2012
Last night, I finished the underside with WPU/Spackling mixed. I also started experimenting with the right thinners for my cheap artists acrylics. I found that windolene (windex) did a remarkable job. My cheap airbrush I recently purchased, has a much larger nozzle and handled the thinned acrylic perfectly. I gave a light coat to the upper surface, but before I spray it properly, I'm still working on getting a decent join between my canopy and fuselage pieces, which I'm hoping to do tonight....
Old Oct 31, 2013, 06:15 PM
Isaiah 40:31
Clickety's Avatar
Joined Sep 2012
First few coats, a little sanding still required in places. I found that mixing 40% ethanol, 10% windex and 50% paint works well and dries quickly too. Canopy is just rested on top for now, I need to complete the cockpit
Old Nov 02, 2013, 04:55 AM
Isaiah 40:31
Clickety's Avatar
Joined Sep 2012
Just had a few moments to upload my finishing guide, its a work-in-progress, and I will substitute some of the proto-images when the gray ghost is complete- its about 60% complete, but I thought it might be of interest. Any thoughts or suggestions welcome...
I've currently finished my cockpit, all painted and decalled, and have glued my canopy down using hot melt glue. I've also masked the 'upper edge window frame' and applied filler to the edge between the canopy and fuselage get a really smooth transition between the fuselage and canopy - like the original.
I will upload photos when I have a few minutes...busy weekend lined up....
ciao for now!
Old Nov 06, 2013, 03:42 PM
Isaiah 40:31
Clickety's Avatar
Joined Sep 2012
been a busy bee, but made some progress. I've finished painting it, and I'm applying decals and drawing panel lines over the next few days. I'll upload when finished so as not to spoil the final effect!!
Old Nov 11, 2013, 12:54 AM
Isaiah 40:31
Clickety's Avatar
Joined Sep 2012
Had a funeral to attend and a weekend away, will try to finish and upload pics this week.
Old Nov 14, 2013, 03:47 PM
Isaiah 40:31
Clickety's Avatar
Joined Sep 2012
Nearly there
Got a few odd little jobs to do on it but I couldn't wait to show some pics! The underside needs panel lines adding etc
Old Nov 14, 2013, 09:51 PM
Caddguy6's Avatar
Philadelphia, PA
Joined Jan 2002
Beautiful!
But noticed an oops with the markings. The stars and bars on the right side of the fuselage and the top of the wing are pointing the wrong way. The star top always points up, like on the left side. And on the wing, the top point always faces forward. Other than that it's absolutely beautiful.
Caddguy6 is online now Find More Posts by Caddguy6
Old Nov 15, 2013, 02:21 AM
Isaiah 40:31
Clickety's Avatar
Joined Sep 2012
Oh dang! Well spotted. Easy to fix as they are vinyl cut... Thanks
Old Nov 15, 2013, 05:22 AM
Caddguy6's Avatar
Philadelphia, PA
Joined Jan 2002
Glad those weren't painted on! Just an outstanding build.
Old Nov 15, 2013, 01:15 PM
Hampton, VA
Joined Mar 2009
Clickety,
Thank You for the time and effort you put in on this project. It's an awesome build. Best of luck with the flight testing!
Ksqm
ksqm is offline Find More Posts by ksqm
Old Nov 15, 2013, 01:18 PM
ltc
AMA 97737
ltc's Avatar
United States, MA, Mendon
Joined Mar 2010
I believe that this plane needs to be sent across the pond in the spring in order to complete a thorough North American flight test programme
Amazing effort and results ... one of the best RCG threads
ltc is online now Find More Posts by ltc
Old Nov 15, 2013, 03:53 PM
Isaiah 40:31
Clickety's Avatar
Joined Sep 2012
Thank you all so much for your support and encouragement guys I really appreciate it. Next step is to repair the proto to complete the cg experiments which is well underway. I've also almost finished cutting another set of parts for the black widow edf version which I'm optimistically trying to complete before January. Will also take more pics of the ghost hopefully tommorrow when I finish the underside. Thanks again - can't wait to see the North American trials in spring
Old Nov 16, 2013, 07:57 AM
Isaiah 40:31
Clickety's Avatar
Joined Sep 2012
I took the model into the garden for a few photos. I held it in the air and my daughter photographed it, I then edited out my arm so that you can see it 'flying'.
I hope the actual flying photo's will be as sharp!
New Product YF-23 Northrop Grey Ghost 2 x 70mm mopetista Foamy EDFs 43 Apr 04, 2014 12:45 PM
The Start of my YF-23 Black Widow II Project RCWorks Foamies (Kits) 39 Jul 14, 2009 07:24 PM
Discussion YF 23 Black Widow Eaglehawk752 Pusher Prop Jet Models 2 Sep 28, 2006 01:50 AM
Northrop/McDonnell Douglas YF-23 Black Widow II Esprit440 Pusher Prop Jet Models 12 Jul 31, 2006 12:47 AM
Yf-23 Black Widow Twin Midi Plane Crazy Electric Ducted Fan Jet Talk 23 Feb 08, 2005 03:25 PM
