Old Sep 18, 2012, 07:12 AM
Build and Fly!
SpaceAviation's Avatar
Philippines, NCR, Manila
Joined Sep 2012
Philippine Airlines B777-300ER 1:45 scale
change of plan from 1:38 scale going down to 1:45 scale
70 Asia's first shining through
SpaceAviation is offline Find More Posts by SpaceAviation
Old Sep 18, 2012, 07:15 AM
Build and Fly!
Joined Sep 2012
I will use Change Sun high performance 70MM 10 blade EDF unit.
any suggestions or comments to make this plane fly? how about the thrust?
I would like to achieve a 3.5+kg or more.
Happy flying!
Old Sep 18, 2012, 07:49 AM
Up-Out-&-Gone
demondriver's Avatar
Charelston SC U.S.A.
Joined Mar 2007
Happy flying!
I would use some good Change sun 90mm or HET 90mm Edfs and some good 80Amp Hobbywing ESC's and good 40C+ 5 or 6 Cell Lipos
This is gonna be a great build! subbed by Space-A!
demondriver is online now Find More Posts by demondriver
Latest blog entry: Introducing The "Demon-Claw"...
Old Sep 18, 2012, 08:06 AM
abroadhurst94's Avatar
United Kingdom, England, Lincoln
Joined Jun 2011
Subbed!
If you want to go with 70mm CS fans, have a look at this thread. It shows the test results with different motors with 4/5/6 cell lipos to help you pick the right one for the performance you're after
abroadhurst94 is offline Find More Posts by abroadhurst94
Old Sep 19, 2012, 05:05 AM
Build and Fly!
Joined Sep 2012
i will use these:
4S Test Results:
Cyclone CP-480-3300kv
SkyLipo 4S 40C
Vm: 13.19
Ap: 89.57
Wp: 1297.0
Thrust(kg) 1.83
g/w: 1.41
5S Test Results:
Turnigy L2855 - 2100kv
5S 4400 65C
Vm: 18.82
Ap: 54.70
Wp: 1067.10
Thrust (kg): 1.8
g/w: 1.69
Old Sep 19, 2012, 05:07 AM
Build and Fly!
Joined Sep 2012
how about the servos? how many servos i would need if my specs are..
ailerons
elevator
rudder
flaps ( takeoff and landing)
gear doors
retracts??....
Old Sep 19, 2012, 05:26 AM
Up-Out-&-Gone
Joined Mar 2007
ailerons
elevator
rudder
gear doors
retracts??....
15-20 gram mini servos
2 ailerons
4 or 2 flaps
2 elevators
1 rudder
1 nose wheel steering
And maybee you should use 3 servoless retracts.
Old Sep 19, 2012, 06:32 AM
Build and Fly!
Joined Sep 2012
which is better?
http://www.hobbyking.com/hobbyking/s...5kg_0_13s.html
or
http://www.hobbyking.com/hobbyking/s...5kg_0_14s.html
Old Sep 19, 2012, 06:33 AM
Build and Fly!
Joined Sep 2012
the flaps are optional
Old Sep 19, 2012, 06:55 AM
Up-Out-&-Gone
Joined Mar 2007
Mike I would say the lower one is the better option Sir. . .. but either one of these might be too small for your control surfaces. . . .you might wanna moove up from Micro to mini servos and pic a metal gear servo like the carona which have NEVER failed me and have solid reviews.
Old Sep 19, 2012, 07:07 AM
Build and Fly!
Joined Sep 2012
i will buy MG servos for the aeilrons. rudder and elevator only
but the gear doors and nose wheels steering is onyl an ordinary servo?
is that okay? or do you know some servo combo packages?
Old Sep 19, 2012, 07:39 AM
Up-Out-&-Gone
Joined Mar 2007
Last time I checked Nitroplanes has some edf esc & servo combos
And a regular mini servo is fine for nose gear steering.
Old Sep 19, 2012, 07:43 AM
Fly it like you STOL it!
Keenan smith's Avatar
United Kingdom, London
Joined Dec 2010
Would you like My 1:30 scale 777:300ER Plans ....
Keenan smith is offline Find More Posts by Keenan smith
Old Sep 19, 2012, 08:16 AM
Build and Fly!
Joined Sep 2012
i would like to! =) sure =) send through message please =)
Old Sep 19, 2012, 08:39 AM
Joined Dec 2010
Okey doke PM Me your Email and ill send them..
Build Log Saudi Airlines 1:23,46 scale Cargo MD-11 azzou RC Airliners (Commercial, Cargo, Troop Carrier) 67 Aug 27, 2013 08:44 AM
Build Log HMS Diamond Type 45 1/96 Scale type45 Scale Boats 84 Mar 22, 2013 06:12 PM
Build Log DreamFactory: 1:22 Scale Air Canada 2.11m 777-300ER Keenan smith RC Airliners (Commercial, Cargo, Troop Carrier) 362 Dec 18, 2012 06:14 PM
Build Log B777-300ER 1:38scale SpaceAviation RC Airliners (Commercial, Cargo, Troop Carrier) 25 Sep 12, 2012 07:44 AM
Build Log B777-300ER 1:40 scale SpaceAviation Batteries and Chargers 1 Sep 09, 2012 11:16 AM
