Old Jan 26, 2009, 09:58 AM
eye4wings is offline
Find More Posts by eye4wings
...design-build-fly-publish...
eye4wings's Avatar
Ware, herts. U.K.
Joined Sep 2008
Question
Jeti 45 -3P opto
I have a Jeti 45 - 3P opto ESC and have lost the instructions that came with it. I have been trying to find out how to disable the brake function and, having failed so far, wonder if any of you has the instruction sheet you could email me?
The Jeti website was pretty much a waste of time.
eye4wings is offline Find More Posts by eye4wings
Old Jan 27, 2009, 11:02 AM
Walt Thyng is offline
Find More Posts by Walt Thyng
Walt
St. Charles, Illinois
Joined Aug 2003
Try Hobby Lobby. In the meantime I'll find the instructions on the Jetis I have and get back to you later today.
Walt
Walt Thyng is offline Find More Posts by Walt Thyng
Old Jan 27, 2009, 11:24 AM
Walt
Joined Aug 2003
Sometimes it pays to be organized. Here's the quote from the Jeti instructions for the enitire Advance series, including the Opto 40.
"The speed controller is supplied with the "brake" activated. If you want to turn off the brake, do the following:
-Switch on the transmitter and move the stick to full throttle.
-Connect the main power pack and turn on the receiver switch (if used).
-Wait 5 seconds.
-After 5 seconds you will hear four tones.
-Swiftly move the throttle stick back to the closed position; you will hear two 'beeps'.
-The brake is now turned off.
"The brake setting will not change after disconnecting the main power pack. When turning on the speed controller with the brake active, you will always hear one 'beep'. When the brake is turned off you will hear two 'beeps'. If you want to activate the brake again, repeat the procedure."
I have double checked the above twice.
Glad I could help,
Walt
Old Jan 27, 2009, 11:26 AM
jonnyjetprop is offline
Find More Posts by jonnyjetprop
jonnyjetprop's Avatar
USA, FL, Apopka
Joined Sep 2003
Here you go. It on the Jeti web site under products/ oldies
John
jonnyjetprop is offline Find More Posts by jonnyjetprop
Old Jan 30, 2009, 04:22 AM
eye4wings's Avatar
Ware, herts. U.K.
Joined Sep 2008
Thanks JJP! That does the job!
When I went on the Jeti website I must have completely missed the /oldies route. I'm not sure I would have connected the word with something I bought only about 5 years ago - but I suppose things are moving pretty fast in this hobby!
Thanks again.
(over and out)
Sold For Sale: JETI Advance 45 3P Opto ESC New in Package Buran Aircraft - Electric - Power Systems (FS/W) 1 Nov 20, 2008 09:23 PM
For Sale Jeti Phasor 45/3 & Jeti 40-3P Opto ESC mavdriver Aircraft - Electric - Power Systems (FS/W) 2 Apr 12, 2008 05:35 PM
Phasor 45/3 and Jeti 40-3P opto spd cntrl. TurboFanElectric Aircraft - Electric - Airplanes (FS/W) 8 Nov 29, 2002 05:13 PM
Feedback - Jeti 70-3P OPTO - Capacitor Tests NipponDave Power Systems 0 Oct 23, 2001 10:29 AM
Jeti 70-3P OPTO Blows Cap... why? NipponDave Power Systems 5 Oct 04, 2001 10:13 AM
