Old Jun 11, 2007, 03:42 PM
DeeBee1 is offline
Find More Posts by DeeBee1
DeeBee1's Avatar
United Kingdom, England, Brighton
Joined Apr 2007
Speed 280 Model Plans
This probably sounds odd, but I have trawled the net for plans for speed 280 powered models and there are surprisingly few. I'm after a 3 or 4 channel, balsa build (not a 'profile' model). Scale or not - I don't mind as long as someone has actually built and flown at least one, it's not depron, and it doesn't consist of just a carbon stick with wings!
I have a couple of 280's spare and the need a purpose in life!
Any ideas/plans appreciated.
DeeBee1 is offline Find More Posts by DeeBee1
Old Jun 11, 2007, 10:27 PM
JLSalas is offline
Find More Posts by JLSalas
JLSalas's Avatar
Santiago Pudahuel, Chile
Joined May 2003
Maybe not for 280, but with some changes...
http://www.rcgroups.com/forums/showthread.php?t=222060
hope this help
Juan Luis
JLSalas is offline Find More Posts by JLSalas
Old Jun 11, 2007, 10:46 PM
youth must fly is offline
Find More Posts by youth must fly
feel no remorse
youth must fly's Avatar
underground
Joined Jun 2004
That cherokee sure is pretty but way to fragile. I dont have the nervous if i would crash that thing.
The body frame is way shock sensitive any bad mishap and your going home with a little bag of toothpicks
Think about it
youth must fly is offline Find More Posts by youth must fly
Old Jun 12, 2007, 12:17 AM
oldcoot88 is offline
Find More Posts by oldcoot88
Joined Dec 2002
This model is no longer available, but the specs on it may give you some worthwhile parameters for a scratchbuild.
http://www.greathobbies.com/producti...od_id=HLIFA280
I have scratchbuilt planes using the 280, and used the Gunther prop shown on this plane (the ever-popular 4.9 X 4.3 'Wingo/Zagi' prop). You need a prop of at least 3 inch pitch for decent performance with the 280.
oc88(Bill)
oldcoot88 is offline Find More Posts by oldcoot88
Old Jun 12, 2007, 01:17 AM
groundfx is offline
Find More Posts by groundfx
Delta, BC, Canada
Joined Oct 2003
280 model heaven here: http://www.bmjrmodels.com/catalog.cfm?ID=Park%20Flyers
and here: http://www.bmjrmodels.com/catalog.cfm?ID=Texaco
There are a few 280 power planes in the "Stik" series here: http://www.modelairtech.com/stik.html.
Review of one here: http://www.rcgroups.com/forums/showthread.php?t=518296
Look for the Easybox 2 here: http://pldaniels.com/flying/
Review here: http://www.rcgroups.com/forums/showthread.php?t=597303
Then there are the Herr "Breazy Day Flyers" see kits here:
http://www.greathobbies.com/producti...rod_id=HRRK302
http://www.greathobbies.com/producti...rod_id=HRRK303
http://www.greathobbies.com/producti...rod_id=HRRK304
http://www.greathobbies.com/producti...rod_id=HRRK305
For something completely different, I would bet you could convert the Fournier RF-4 on this page (http://my.pclink.com/~dfritzke/) to a Speed 280.
Similarly, the Fred Reese Littlest Stick on the same page would make for a good conversion with light gear and small lipos.
How's that for a few? :-)
Let us know what you build...
groundfx is offline Find More Posts by groundfx
Old Jun 12, 2007, 07:55 AM
pac ace is offline
Find More Posts by pac ace
pray for our troops
pac ace's Avatar
Farmington Hills, MI
Joined Jul 2005
DeeBee,
I currently have an s280 in a 2.8:1 gearbox in a Dumas Waco ARE and am using a 3s800 8c Lipo to power it. Though the specifications for the Dumas r/c models state that they are designed for IPS and 2s lipos the set up I have works really well. Though I'm not sure if the geared 280 will fit into one of the high winged planes (I'm pretty sure that one won't fit into the Pilatus Porter cowl) I'm pretty sure that it would work with any of the biplanes.
http://www.dumasestore.com/catalog/i...hp?cPath=50_63
These Pat Tritle models were also designed for a geared s280.
http://www.manzanolaser.com/id46.html
http://www.manzanolaser.com/id51.html
Rob
pac ace is offline Find More Posts by pac ace
Old Jun 12, 2007, 08:06 AM
pac ace is offline
pray for our troops
pac ace's Avatar
Joined Jul 2005
Oh, and the plans for the Piper Cherokee that Juan Luis linked you to are available through here:
http://www.rcstore.com/ME2/dirmod.as...tier4=&ntier5=
Old Jun 12, 2007, 09:45 AM
mt_100 is online now
Find More Posts by mt_100
I have no friends
United States, MI, Holland
Joined Dec 1996
Quiet Flyer had one called the Flit that I have plans for. DD speed 280 aerobatic plane that is pretty fun and easy to build.
http://www.kionapublishing.com/catal...8a061bd7735bc3
mt_100 is online now Find More Posts by mt_100
Old Jun 12, 2007, 12:32 PM
feihu is offline
Find More Posts by feihu
feihu's Avatar
Sun City, AZ
Joined Jun 2002
Here is a park flyer that I designed and built about 5 years ago. Beautiful flyer, and you can taxi, takeoff , and land on a smooth surface. 30" span, balsa sticks with film covering, speed 280 w/ 5:1 gear and 9x6 prop. After years of flying, now set aside for using the radio in another plane.
Recently got in CAD and put the plans there. Altho the plans may lack some detail, it has all the necessary info to build. If you are interested, I can send you the plans in DXF format if you have CAD, otherwise I would have to reformat the plans in a PDF file to print in 12 sheets of 8 1/2 x 11 paper.
feihu
feihu is offline Find More Posts by feihu
Old Jun 12, 2007, 02:21 PM
DeeBee1 is offline
DeeBee1's Avatar
Joined Apr 2007
Thanks to everyone who has replied so far. Plenty here for me to think about.
Old Jun 12, 2007, 08:54 PM
bevers01 is offline
Find More Posts by bevers01
Brandon Evers
bevers01's Avatar
United States, CA, San Diego
Joined Jan 2006
I definitely recommend Tom Hunt's Stik series. I have plans for the Miss Stik Jr and the Elipstik 260 I can send you if you'd like. (I built both from a kit and copied the plans so I didn't have to cut up the originals.)
-Brandon
bevers01 is offline Find More Posts by bevers01
Old Jun 12, 2007, 11:39 PM
BEC is offline
BEC
Find More Posts by BEC
BEC
BEC's Avatar
Auburn, Washington USA
Joined Jan 2001
-Brandon
Skimpy from the Stik series is for geared 280 as well - I had one of those for quite a few years. Good little sport plane.
BEC is offline Find More Posts by BEC
Old Jun 13, 2007, 09:53 AM
Griffin is offline
Find More Posts by Griffin
WAA-08 Survivor
Griffin's Avatar
Joined May 2004
-Brandon
Except you would be using plans without paying anything to the designer. It's up to you how much you care about being ethical...
As far as speed 280, I second Tritles designs--he has quite a list of plans and short kits specifically for the geared 280.
Also look at Peter Rake plans. Many in this size range.
http://
www.peterrake.com/php/Main.html
-Steve
Griffin is offline Find More Posts by Griffin
Old Jun 13, 2007, 07:55 PM
bevers01 is offline
Brandon Evers
bevers01's Avatar
Joined Jan 2006
Excellent point. I was trying to help out and didn't realize the implications. I guess I'll save them in case I build another (I paid for both kits so that better be kosher ). Sorry, DeeBee.
-Brandon
Old Jun 13, 2007, 09:45 PM
Pat Daily is offline
Find More Posts by Pat Daily
Pat Daily's Avatar
United States, VA, Chesterfield
Joined Mar 2001
Enlarge a P-nut scale ff plane to about 36 inches and a 280 power unit will do just fine.
Pat Daily is offline Find More Posts by Pat Daily
Herr Mini Sport - Speed 280, Laser Cut Kit hoppy Electric Plane Talk 19 Jul 29, 2001 11:43 AM
Direct Drive Speed 280 Benefits? Dave Hederich Electric Plane Talk 27 Jul 14, 2001 11:34 AM
HERR Speed 280 Planes - 4 new ones hoppy Electric Plane Talk 7 May 11, 2001 11:48 AM
New HERR Speed 280 Planes that will fly in wind. Looooeeee! Electric Plane Talk 5 May 08, 2001 01:51 PM
Graupner Speed 280 Question greg Beginner Training Area (Aircraft-Electric) 10 May 03, 2001 04:57 PM
