Old Sep 14, 2002, 10:13 AM
Doc Data is offline
Find More Posts by Doc Data
United States, FL, Starke
Joined Apr 2002
Compatible sanding sealer?
I'm building an Aquila sailplane (the kit produced in the 70's) and intend to paint the fuze using TopFlight's LustreKote to match the Monokote color. I have the paint and the covering already.
I need to know what is a good and compatible sanding sealer. The paint can warns about using 'compatible' products with the color. I don't want to seal the balsa/ply fuze and have the paint peel off later. The guy at the store thought the LustreKote was a polyurthane but was not sure. If so, I could get a polyuthane sanding sealer or make one from clear polyurthane and some talc.
Any ideas?
dd.
Doc Data is offline Find More Posts by Doc Data
Discussion Sanding sealer HoverTim Scale Boats 4 Jun 02, 2007 02:23 PM
JK Perkins Sanding Sealer thething84 Scale Boats 10 Apr 11, 2005 04:00 PM
Foam Sanding Sealer / Filler : Tip BlueFielder The Builders Workshop 3 Jun 28, 2003 04:44 PM
Sanding Sealer & 'cote? tiggs Electric Plane Talk 4 Jun 18, 2001 11:39 AM
