Old Sep 23, 2004, 03:59 PM
speedchaser is offline
Find More Posts by speedchaser
speedchaser
Brighton, Great Britain (UK)
Joined Sep 2004
Idea
Big Props on Airboats
I've sometimes thought of Airboats as there's less construction and they're very flat which I like, but the size of the props I've seen in pics puts me off - the diameter's so large - they look so out of scale/synch to the boat itself; I've been thinking that if you ducted the prop you might gain some cosmetic value - but probably not much... I guess the size of the props on Airboats is because there's less resistance in air than in water - and so the prop has to be big to draw in enough air (is that right...)? But if you turned the motor/prop around so that is pushed against the air rather than pulled on it (just as a water prop pushes agains the water), could you get away with a smaller diameter prop - just a thought... Any clues...?
speedchaser is offline Find More Posts by speedchaser
Old Sep 23, 2004, 06:16 PM
CG Bob is offline
Find More Posts by CG Bob
KC8WPF
CG Bob's Avatar
Euclid, Ohio, United States
Joined Sep 2004
Full size airboats tend to have large props. Air is not as dense as water, and need a larger diameter screw. Husky Airboats specs show a 6 foot diameter 6 blade prop on a 19 foot airboat. In the Wisconsin Apostle Islands area of Lake Superior, they use wind sleds to get out to the islands in winter. Wind sleds are reinforced for use over the ice, and look like airboats with a cabin.
...and so the prop has to be big to draw in enough air (is that right...)? But if you turned the motor/prop around so that is pushed against the air rather than pulled on it
It doesn't matter too much if the prop is in front of or behind the motor. The prop still has to cut into the air on one side to push the air out the other. Think of a nut threaded onto a bolt, it takes the same amount of energy to turn the nut in either direction. The nut is similar to the prop on an airboat.
CG Bob is offline Find More Posts by CG Bob
Old Sep 24, 2004, 03:41 AM
speedchaser
Joined Sep 2004
Right - many thanks for that... Full-size examples of marine craft that gave me the notion of smaller diameter props for model rc airboats or similar, are for instance hovercraft, whose props (although large) are relatively much smaller in relation to the hull than those for an rc model airboat. I know that hovercraft have irtually no water resistance for obious reasons, but then nor would airboats especially if they had strakes - so I just thought it might be possible to have smaller props - but your info of a real (?) 19 foot airboat having a 6-foot 6 bladed prop, probably negates that.
Question Using Big Spinners for Folding Props on Scale Aircraft Bosk Power Systems 2 Mar 31, 2007 04:36 PM
Arc-1 and 2 props on sale Chris Hansen Aircraft - Electric - Airplanes (FS/W) 2 Aug 05, 2001 10:55 AM
Break props on flying wings? Red Baron 47 Electric Plane Talk 4 Aug 03, 2001 10:49 AM
Zagi-bending motor shafts using Master Airscrew props on belly flops Balin Foamies (Kits) 7 Jul 22, 2001 08:58 PM
Do you use O-Rings to hold your props on? A cheaper way hoppy Parkflyers 1 Jun 09, 2001 03:03 AM
