Old Mar 30, 2015, 01:03 PM
russert122 is offline
Find More Posts by russert122
Joined Mar 2015
My battery build
Attached is a diagram of my stock bat. and the pack I want to build. The 2 batteries in my drawing are identical 14500 1200mAh 3.7V. I took the plastic wrap off my stock pack, so my wiring diagram is identical to it. Its the huge increase mAh I am conserned about, I think it will double to 2400mAh. Will it fry the electronics and burn my copter to the ground or give me extra fly time? Many Thanks To All
russert122 is offline Find More Posts by russert122
Old Mar 30, 2015, 01:10 PM
Pass1 is offline
Find More Posts by Pass1
Pass1's Avatar
Saudi Arabia, Makkah Province, Thuwal
Joined Aug 2012
I think you are putting the batteries in series, not parallel.
The result is not increased mAh, but increase in voltage, which will most likely fry whatever you are plugging it in.
And your diagram says your batteries are 3.7, but they are 2cells (7.4). I think you need to do a bit more research before you start blowing things up, or a little better explanation.
Pass1 is offline Find More Posts by Pass1
Old Mar 30, 2015, 01:17 PM
Joined Mar 2015
You are correct 2x 3.7 = 7.4v What will the huge increase in mAh do to my copter?
Old Mar 30, 2015, 01:29 PM
Mad_Mike is online now
Find More Posts by Mad_Mike
Be safe son - Fly low and slow
Mad_Mike's Avatar
Canada, ON, Lyn
Joined Feb 2015
So your stock battery is 7.4V.
The battery you want to build will also be 7.4V but 1200mAh instead of 650mAh.
The result will be longer flight time, not quite double.
Mad_Mike is online now Find More Posts by Mad_Mike
Old Mar 30, 2015, 01:41 PM
FiftySlicks is offline
Find More Posts by FiftySlicks
United Kingdom, Scotland, Edinburgh
Joined Jun 2014
The highest capacity 14500 cells top out around 800mAh or so, I strongly suspect your claimed 1200mAh cells are junk.
FiftySlicks is offline Find More Posts by FiftySlicks
Old Mar 30, 2015, 01:56 PM
Mad_Mike's Avatar
Canada, ON, Lyn
Joined Feb 2015
He intends to use 1200mAh batteries in the new pack.
The diagram is untidy and causing confusion IMO.
Old Mar 30, 2015, 02:41 PM
Pass1 is offline
Pass1's Avatar
Joined Aug 2012
Ok, I think I finally understand what's happening.
The more mAh the better, if that was the only thing changing you would just get longer flight times. It's like putting more fuel in the car. The only sad part is that more fuel means also more weight so there is a point where more mAh means so much weight that you actually fly for less, or fly like a pig. Finding the perfect balance is not easy!
Good luck!
Old Mar 30, 2015, 03:24 PM
ggcrandall1 is online now
Find More Posts by ggcrandall1
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
May I suggest you read this: http://www.tjinguytech.com/charging-how-tos
But briefly:
Adding cells in series does not increase the mAh.
Adding cells in parallel does increase the mAh.
Adding cells in series does increase the voltage.
Adding cells in parallel does not increase the voltage.
Adding mAh does not force more current into the motor.
Adding voltage will increase the current in the motor.
Glen
ggcrandall1 is online now Find More Posts by ggcrandall1
Old Mar 30, 2015, 10:39 PM
Joined Mar 2015
Thanks a lot for all the info
Old Mar 30, 2015, 10:55 PM
Wintr is online now
Find More Posts by Wintr
Wintr's Avatar
USA, MO, Florissant
Joined Nov 2010
Good luck!
Or, not be able to fly at all. Before you start building a battery, I suggest you find out how much heavier the battery will be than the current battery, and attach that much weight to the model. Then you'll know how it will fly with the extra weight, if it flies.
Wintr is online now Find More Posts by Wintr
Build Log Need help for my first build: My 250FPV-L Racer Cente Mini Multirotors 9 Jan 20, 2015 11:13 AM
Discussion My Battery doesn't give me 3 beeps for my battery what's happening hog2soar Power Systems 0 Jan 17, 2015 10:47 AM
Help! My first hexacopter build looking to use Li-Ion batteries. Spartakus109 Multirotor Power Systems 4 Jan 12, 2015 05:57 AM
Help! Battery for my build headviking Multirotor Talk 1 Oct 03, 2014 10:42 AM
