Old Dec 29, 2014, 03:22 PM
fanderson94 is offline
Find More Posts by fanderson94
Joined Dec 2014
Help!
Lian Sheng LS-112 :confused:
I got a Lian Sheng LS-112 whilst in Hong Kong.
However it will not connect with the control. I have tried everything.
Any ideas what I can do
fanderson94 is offline Find More Posts by fanderson94
Old Jan 02, 2015, 03:08 AM
Heli Pad is offline
Find More Posts by Heli Pad
Against Helicopter Cruelty
Heli Pad's Avatar
Joined Aug 2011
Sorry to hear that. It sounds like taking it back for an exchange is out of the question. If you are stuck with it, be ready to stomach that it is defective and you got a dud.
But, let's go through a few checks before we call it DOA. First, I assume that you have fully charged the helicopter? Next, I assume that you have good batteries in the remote?
When you turned on the remote, was there any lights? If so, what color?
When you turned on the heliocpter, was there any lights? If so, what were they doing?
Now, be sure to set the helicopter on a solid surface and let the gyro have a chance to initialize. It only takes a few seconds. But you won't believe how many people miss this and reported that the unit doesn't work.
If after all these and there is still no luck, we have a bigger problem. Next, try to determine if the remote is even sending signals. To do that, look through your phone's camera (very sensitive to Infra-Red lights, which our eyes could not see) and check if the remote is sending IR signals.
Heli Pad is offline Find More Posts by Heli Pad
Old Jan 05, 2015, 04:04 AM
LittleFish is offline
Find More Posts by LittleFish
LittleFish's Avatar
Canada, ON, Toronto
Joined Sep 2014
It's a 2.4 GHz radio controlled device, no?
LittleFish is offline Find More Posts by LittleFish
Old Jan 05, 2015, 10:32 AM
Heli Pad is offline
Heli Pad's Avatar
Joined Aug 2011
Yes, you are correct. After finding this post in the coaxial helicopter group, I got it mixed up with an IR controlled helicopter with similar model name.
Old Jan 05, 2015, 03:29 PM
Joined Dec 2014
The lights on the helicopter just flash very fast for a few seconds when first turned on then they flash constantly.
The light on the control flashes to start with and there is 4 bleeps then a constant red light
Old Jan 07, 2015, 04:06 PM
mihcmac is offline
Find More Posts by mihcmac
mihcmac's Avatar
United States, HI, Keaau
Joined Aug 2013
this might help..
Lian Sheng - LS-112 - Review and Flight (8 min 7 sec)
mihcmac is offline Find More Posts by mihcmac
Discussion Lian Sheng LS-222 Problem anggawirap Coaxial Helicopters 3 Dec 29, 2014 03:14 PM
Help! Lian Sheng LS 222 Helicopter Nik0 Coaxial Helicopters 3 Jun 16, 2013 03:48 AM
