Old Feb 22, 2013, 12:59 PM
propaplace is offline
Find More Posts by propaplace
United States, FL, Titusville
Joined Jan 2007
Classic vs Old Time vs Nostalgia
Howdy y'all! Please don't anyone be upset with me but I was wondering what defines a "classic plane" i.e. Old Time, Nostalgia 30? I'm sure it has been written out in the past but I missed it and I couldn't find the definition. For example what catagory would a Ringmaster S-1 be .... how about a Bi-Slob ....or say a Novi III ....?? What about a design like the Ruffy or Skylark that has been "upgraded" i.e. scratchbuilt using more modern techniques and materials, how would it be classified?? I ask this because I've scratchbuilt a Sig Banshee but I made foam cores for the wing then I scratchbuilt a Ringmaster S-1 variant but I goofed and cut the foam core backwards, that is the leading edge trails back and the trailing edge is straight (boy did I goof that setup). Nevertheless I went ahead and sheeted the wing and used it. It still flew just fine but it definately looks different from the original Ringmaster and my Banshee flies just fine and pulls like crazy with the OS 40FP providing the pull.
propaplace is offline Find More Posts by propaplace
Old Feb 22, 2013, 02:08 PM
slipstick is offline
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
Competition classes all have clearly stated rules as to what is allowed in that class. And the classes and their definitions vary widely across the world.
Outside of competition classes it's down to personal opinion. You can call your models whatever you like .
Steve
slipstick is offline Find More Posts by slipstick
Old Feb 22, 2013, 09:48 PM
Joined Jan 2007
Thanks! My problem is that I built a model on a plane called the Novi III but I made some modifications; one of which is fairly significant. I made the canopy from a carved block of balsa vs forming one from plastic sheet, I built-up the lower cowl from balsa rather than fiberglass and finally I made the wing removable! I'm just not sure if that "unmakes" it Novi III. From 5 feet I'm not sure anyone would really know the difference, but I sure would like to know the cutoff! Can anyone make the call??
Old Feb 23, 2013, 05:31 PM
Jim Thomerson is offline
Find More Posts by Jim Thomerson
Unfortunately, the definitions of the different classes, and how they are judged are different among different countries. Here in the USA, there are supposed to be Fidelity Points in Classic (airplanes through 1969), but, for obvious reasons, they are seldom used, with appearance points used instead. I'd say your airplane should be OK.
Jim Thomerson is offline Find More Posts by Jim Thomerson
Old Feb 24, 2013, 09:51 PM
stuntflyr is online now
Find More Posts by stuntflyr
stuntflyr's Avatar
Los Angeles
Joined Jun 2010
OTS in the USA is up until Dec31, 1952, Classic is up until Dec31, 1969 and Nostalgia '79 is up until Dec31, 1979. The Novi III is a Classic in the USA. Your model is legal too.
Chris...
stuntflyr is online now Find More Posts by stuntflyr
Old Feb 25, 2013, 07:04 AM
perttime is offline
Find More Posts by perttime
perttime's Avatar
Tampere, Finland
Joined Nov 2004
As far as I have understood discussions on the US Classic class, it has to look like the "original". What you do with things that are not all that visible is up to you.
perttime is offline Find More Posts by perttime
Off Site 50" Commando old time FF/Electric sunderll Aircraft - Electric - Airplanes (FS/W) 0 Jan 05, 2013 01:46 PM
Discussion Dynaflite Bird of Time: Old vs. New eteet Sailplane Talk 22 Aug 13, 2011 06:54 PM
Yippee! Classic Old Time Engines Replica Deezil CashRC Vintage & Old-Timer Designs 20 Jan 27, 2011 10:54 AM
Discussion Old time /Classic dankar04 Control Line 2 Jul 26, 2008 03:38 PM
Discussion More Nostalgia: Old School Pics, late 80's or early 90's Davenport ISR KurtMc Slope 3 Jul 27, 2006 01:26 AM
