Old Jun 20, 2010, 05:11 PM
MattyB is offline
Find More Posts by MattyB
Taranis Tyro...
MattyB's Avatar
United Kingdom, England, Hitchin
Joined Jan 2004
Question
2mm balsa equivalent; 1/16 or 3/32?
Building a Crobe 2, and the plan calls for 2mm balsa for most of the fuse. I'd always thought 2mm equivalent to 1/16, but it turns out 1/16 is only 1.59mm, whilst 3/32 is 2.38mm. I'm still thinking of going for 1/16, partly because it's doubled with 1/64 ply for much of the fuse, and partly cos I ain't got no 3/32! Reckon it'll be ok?
MattyB is offline Find More Posts by MattyB
Old Jun 20, 2010, 05:19 PM
steve wenban is offline
Find More Posts by steve wenban
Crikey never leave beer behind
steve wenban's Avatar
Mt Annan Sydney Australia
Joined Dec 2003
yeah milled sizes don't exactly tie up but basic 1.5mm= 1/16", 2.5mm =3/32" 3.0mm=1/8"
personally Mat i'd use the 2.5 mm as it gives you a bit of room for error when sand back.
But as you say its backed with ply and would be solid anyway ,I just like to have a bit of material to work with to be able to get a correct shape when sanding with out getting air thin.
SteveW
steve wenban is offline Find More Posts by steve wenban
Old Jun 20, 2010, 05:20 PM
yellowblue is offline
Find More Posts by yellowblue
yellowblue's Avatar
west yorks. UK..Home of the Hudds mafia
Joined Apr 2006
Matty, use 1/16"...Plans are meant to be changed...I even change my own plans as I'm building. Enjoy the build.
I must get down to Ivinghoe this summer...
yellowblue is offline Find More Posts by yellowblue
Old Jun 20, 2010, 05:36 PM
MattyB is offline
Taranis Tyro...
MattyB's Avatar
Joined Jan 2004
Good points Steve, but this thing is so damn small I won't really be sanding it round; all I plan to do is take the corners off where there is 4mm triangle section. Will have to make sure I'm especially careful if I do use the 1/16 though!
Thanks mate. Let me know when you're coming down, and I'll negotiate a pass (it takes some prior warning/bribery these days now junior is here...!)
Old Jun 20, 2010, 05:51 PM
yellowblue's Avatar
Joined Apr 2006
Will do Matty, hope Junior is doing well an not keeping you awake to much
Old Jun 24, 2010, 10:24 AM
MattyB is offline
Taranis Tyro...
MattyB's Avatar
Joined Jan 2004
An idiots update... I bought the only sheet of 3/32 in Stevenage earlier this week, only to get it home and find it was 1/8 that had been mis-labelled... Decided I couldn't be ed to wait any longer, so took half a mm off with a sanding block, cut out the fuse sides, then took off some more towards the back to save weight. I figure the front can afford to be thicker, as I'm sure a spot of nose weight will be required.
Wanted 32" or longer basswood stock (1/4" or 3/8") mantraguy Aircraft - General - Miscellaneous (FS/W) 2 Mar 08, 2010 10:09 PM
Question 1/32 vs 3/32 balsa fraggin The Builders Workshop 8 Mar 05, 2010 09:13 AM
Sold HC2808-1 shaft 3.2mm or 1/8" for Himax 2808 Outrunner $2 Mini Buzzard Aircraft - Electric - Power Systems (FS/W) 1 Dec 06, 2009 04:03 PM
WTB: inline gearbox 4:1 or so with 3.2mm (1/8") pinion JoeR Aircraft - Electric - Airplanes (FS/W) 8 Mar 01, 2004 06:22 AM
WTB: gearbox- inline (4:1 or so) 3.2mm pinion, 4mm output, and 16/19mm screw spacing JoeR Aircraft - Electric - Airplanes (FS/W) 2 Sep 10, 2003 12:26 PM
