Old May 07, 2013, 02:23 PM
Joined Jul 2012
lipo rates and limits
ok, so I'm flying a Bixler 2 FPV plane, I'm running a 4s 40c 2650mah pack and it has so much power with the motor im using the thing would probably rip itself apart if i gave it full power punch, so ive came to the conclusion that 3s is plenty for this plane, but i am kinda in the dark on batteries. I was thinking i could use two 3s 30c 2200mah, one of these packs has an amp draw of 66 amps constant, this might be sufficient, but I dont want the packs to get hot, so if two are connected in parallel would this be right: 3s 30c 4400mah???
or would the "C" change to 60 as well?
like i said, I dont all the power the 4s gives me, i can literally cruise at around 45mph at not even a quarter stick, so 3s would be perfect. I figure if im remove the extra weight of a 4s, i could just go for less power and more flight time.
brian.blackshear is offline Find More Posts by brian.blackshear
Old May 07, 2013, 03:01 PM
Dude, I do fly all day long!
rcalldaylong's Avatar
San Jose, California
Joined Dec 2007
3S 30c 2200mah => theoretically 66amps max
3s 30c 4400mah => theoretically 132 amps max
You'd probably fry the batteries at 100amp though
rcalldaylong is offline Find More Posts by rcalldaylong
Old May 07, 2013, 03:02 PM
pilotpete2's Avatar
The Northeast Kingdom, Vermont
Joined Jun 2004
Two 30C 2200mAh packs in parallel would give you a 3S 4400mAh pack with the 30C rating staying the same.
It sure sounds as though your setup was way over amped on 4S, do you have a Wattmeter?
If you have a 3S pack in the 2200mAh range, give it a quick test with a short flight and see what the current draw is with a Wattmeter before going with the dual packs in parallel.
Pete
pilotpete2 is offline Find More Posts by pilotpete2
Old May 07, 2013, 05:29 PM
Joined Jul 2012
Thank you both for the quick reply, both answered my question completely. Ill have to go out this evening for some testing when the wind dies off.
and no, i dont have a watt meter, ill have to look into one soon.
thanks for the advice
For Sale Chaos 600 Pro Limited Edition + Servos, Motor, Tail Servo & 6s Lipo rhampton Aircraft - Electric - Helis (FS/W) 0 May 04, 2013 03:14 PM
For Sale Telink 43" EPP SU-29 Ido Segev "RED" Limited 3D BNF w/ LiPo's - LPU Only - Start $250 JC Spohr Aircraft - Electric - Airplanes (FS/W) 3 Apr 29, 2013 11:18 AM
Discussion Lipo battery discharge rating(S) ham4864 Multirotor Electronics 3 Jan 12, 2013 07:33 PM
Discussion lipo charge rate Bernhard3 Batteries and Chargers 5 Jan 07, 2013 03:14 AM
Question parkzone lipo max charge rate? duker733 Batteries and Chargers 14 Jan 05, 2013 03:01 PM
