Old Feb 25, 2014, 12:14 PM
SoCal
Joined Feb 2004
Original YS .60 Short Stroke Parts
Hi, I am in need of an original YS .60 needle socket. This is the brass piece that screws in to the carb. If you have one you can part with please let me know. Also, if you have any side exhaust engines or other parts you're not needing, please let me know.
Thanks!
TonyF is offline Find More Posts by TonyF
Old Feb 25, 2014, 06:57 PM
United States, GA, Alpharetta
Joined Dec 2007
Tony,
I have a nib .60 side exhaust (older style) for you. Trying to upload pictures.
David
dhal22 is offline Find More Posts by dhal22
Old Feb 25, 2014, 07:26 PM
Joined Dec 2007
Here we go. Doesn't appear to have ever been run. Clean piston, sleeve, no teeth marks, etc. And the older style with the blocky square carb base.
David
Old Feb 28, 2014, 11:12 AM
United States, ID, Kuna
Joined Feb 2008
pristine example of the early sand cast case series
lfinney54 is offline Find More Posts by lfinney54
Old Feb 28, 2014, 07:35 PM
Joined Dec 2007
Thanks. I took a closeup look at the head. It is machined it appears.
David
Old Feb 28, 2014, 07:50 PM
doxilia's Avatar
Montreal, Canada
Joined Mar 2008
David,
these engines were very much like the YS45's. I believe their heads are forged rather than machined. Albeit good forging I must say.
The latter YS60 shorty's had machined aluminum heads which were anodized much like the long AR's but obviously round.
Your engine is certainly a somewhat rare specimen of the early YS60's although not the really early ones which had a separate YS regulator and Enya carb like Yoshioka used in his BA.
David
doxilia is online now Find More Posts by doxilia
Old Feb 28, 2014, 07:56 PM
Joined Dec 2007
Thanks David.
Old Feb 28, 2014, 08:54 PM
SoCal
Joined Feb 2004
Here's a pic of the later model machined head. You can compare this with the pic of David's engine. The "cast" heads were still machined on the exterior and for the fit into the cylinder. But the fins were not machined.
Old Mar 06, 2014, 03:11 PM
Paul Pappas AMA 42520
Pitstop000's Avatar
CT,USA
Joined Aug 2008
Here is another angle/view of the heads of the YS 60's
the later version on the right as you can see is also blocky/squared in shape except for being fully machined.
Description: David's older YS 60 Name: YS 60.jpg
Description: One of mine, newer YS 60
Pitstop000 is offline Find More Posts by Pitstop000
Latest blog entry: JR 28X / JR’s Flagship Radio!
Old Mar 06, 2014, 07:43 PM
Joined Dec 2007
Now I'm going to have to take a closer look at mine.
David
Old Mar 06, 2014, 07:59 PM
SoCal
Joined Feb 2004
I also think the later models were ported differently then the early ones. In these two pics note that the earlier engine on the left has no bridge in the exhaust port like the one on the right. I think the intake ports were also higher on the earlier engine. This was in line with the switch from the high RPM days before the noise rule to the bigger props turning lower RPM's.
Old Mar 06, 2014, 08:12 PM
Joined Dec 2007
This is a solid piece of aluminum. Some say it's cast but it looks machined to me.
David
Old Mar 07, 2014, 03:01 AM
SoCal
Joined Feb 2004
Of course some of that head is machined. You can't get the needed dimensional tolerances purely from a casting. It starts life as a casting then is machined as required. The later model heads were fully machined from a billet. It's really easy to see when you look closely at the fins. They are tapered, slightly thinner at the top then at the base. The outside of the head also shows this slight taper. This is needed to get the part out of the mold. On the "machined" heads there is no taper of the fins.
Old Mar 07, 2014, 06:06 AM
Joined Dec 2007
That helps explain it. Thanks Tony.
David
Discussion (200 engines) NEW YS 60 Rear Exhaust Short Stroke’s (200 engines) Pitstop000 Classic Pattern Flying 61 Apr 14, 2014 09:06 PM
New Product New YS 60 Short Stroke...info Kevin2035 Classic Pattern Flying 33 Jun 16, 2013 01:26 AM
Sold YS. 61 Short stroke Generic Member Aircraft - Fuel - Engines and Accessories (FS/W) 6 Aug 13, 2012 11:53 PM
Wanted YS-60FS side exhaust short stroke Huang Aircraft - Fuel - Engines and Accessories (FS/W) 3 Apr 21, 2012 12:23 AM
Discussion Most commonly replaced parts on YS FZ91 or any YS 4 stroke engine? asad Engines 1 May 02, 2011 11:42 PM
