Old Nov 24, 2013, 10:01 AM
Joined Jun 2011
Helis that have my attention for my next build: Gaui NX4 uses a .37 OS engine.
TT X50. Quality is apparently very good and price is reasonable low.
Ranger71d is offline Find More Posts by Ranger71d
Old Nov 28, 2013, 07:22 PM
Joined Jul 2008
Originally Posted by Ghia View Post
Did the raven TTube, tail rotor or any other proven parts make it into the n640? Or did Century start a totally fresh heli design
It is a totally new design that uses an improved Torque Tube design then my Raven. Rather then taking the front drive off of a crown gear, it takes it off a separate gear system that mates to a big gear attached to the mainshaft. This also results in a smooth and efficient tail drive for autos.
The rotor head is the same great design that has leading edge control with the bell mixers on the blade grips on their FB head. The FBL head has the swash followers articulated in the main hub. Both heads and swashplates are all CNC machined from top grade aluminum.
The tail rotor is a metal version of the Raven's tail rotor with a steel hub and two radial bearings and a thrust bearing in each grip.
The mainframe uses CNC machined bearing blocks and stiffeners sandwiched between two C/F plates.
The clutch system is all metal also, and well supported by bearings in CNC bearing blocks which makes for a very solid & trouble free system.
It also comes with a very attractive PAINTED fiberglass canopy that is a big improvement of the old plastic one that came with the Raven.
Check out the manual here, which will give you a good idea of the quality and precision of the design:
http://www.centuryhelimedia.com/manuals/CN1320N1.00.pdf
When I saw my first one at IRCHA last year, I could not believe they only cost $399!
rotoraddict is offline Find More Posts by rotoraddict
Discussion brand new to nitro just got my first nitro heli a few days ago... old stuff man Fuel Heli Talk 47 May 06, 2013 04:07 PM
Nitro car for a nitro heli wildone Non R/C Items (FS/W) 2 Apr 18, 2013 06:46 PM
Found Want to trade rtr car for nitro heli wildone Aircraft - Fuel - Helis (FS/W) 0 Apr 16, 2013 08:16 PM
Discussion New too helis and want to get a nitro heli???? Jacked11 Fuel Heli Talk 11 Nov 21, 2008 08:34 PM
Wanted Wanted RTR nitro car or truck... new nitro heli to trade!!! FlybyPDX Cars - Cars and Parts (FS/W) 6 May 29, 2006 01:20 PM
