Old Jan 30, 2013, 10:28 PM
unregistered pilot
unitedheavy's Avatar
United States, CA, San Jose
Joined Jan 2013
Idea
Cost-Effective Medium Sized Quad
I'm planning to build a quad, and these are the parts I've picked out, mostly from HobbyKing:
Hobbyking KK2.0 Multi-rotor LCD Flight Control Board
Emax GF2215/20 Outrunner Brushless Motor
Turnigy Multistar 30 Amp Multi-rotor Brushless ESC 2-4S
Turnigy nano-tech 4000mah 3S 25~50C
10x4.5 SF Props 2pc Standard Rotation/2 pc RH Rotation
Q450 Glass Fiber Quadcopter Frame 450mm
HXT 4mm to 4 X 3.5mm bullet Multistar ESC Power Breakout Cable
PolyMax 3.5mm Gold Connectors 10 PAIRS (20PC)
Turnigy Battery Strap 330mm
Gyro / Flight Controller Mounting Pad (10pcs/bag)
Turnigy Accucel-6 50W 6A Balancer/Charger w/ accessories
Hobbyking 105W 15V/7A Switching DC Power Supply
Turnigy Multistar ESC Programming Card
Hobby King 2.4Ghz 6Ch Tx & Rx V2 (Mode 1)
Hobby King 2.4Ghz 6Ch Tx USB Cable
These seem to be the best options for the price. Do you guys think that this will fly? Do I have all the parts I need to start flying? (I'm not missing any wires or that kind of thing right?) Do you guys think I should switch out any of the parts for anything else, any better options?
If this works out, I hope to offer to the community and for retail one of the most inexpensive but reliable quadcopters out there.
unitedheavy is offline Find More Posts by unitedheavy
Old Jan 31, 2013, 01:12 AM
Emress
sirbow2's Avatar
United States, SD, Rapid City
Joined Nov 2011
in terms of weight to power ratio, yes!
A MR in general needs to weigh half the total thrust. max would be 4429g (calc from motor thrust *4) and so half would be 2210g. with everything in the top list, the total weight is 769g. not even near the max
sirbow2 is offline Find More Posts by sirbow2
Question FPV dive in costs for Quad DbleX FPV Talk 7 Jan 07, 2013 02:51 PM
Discussion cost effective quad rotor using arduino smarth Coaxial Helicopters 1 Apr 07, 2009 06:51 PM
Discussion Medium/Low cost camera possibility RidgeTop Aerial Photography 0 Oct 12, 2007 08:36 PM
Discussion Hotliner medium cost harlem68 High Performance 9 Mar 09, 2007 11:14 AM
Wanted Feigao 380 size motor, medium size axi, mega, etc. papasmurf Aircraft - Electric - Airplanes (FS/W) 1 Sep 24, 2005 11:22 PM
