This thread is privately moderated by jcervantes11, who may elect to delete unwanted replies.
Old Jun 24, 2012, 04:26 AM
jcervantes11's Avatar
Joined Sep 2003
Yippee!
My first 2012 build The JS MODEL Tz-v2 Frenzy 50
Hi this is my JS MODEL TZ-V2 FRENZY 50. This is my first build for this year. Been busy lately and so when I came back from Mazatlan Sinaloa Mexico I ordered the Arf. It is 90% built. But I had to take it apart and reapply thread lock and grease on some parts that is needed. I maiden her but still tuning my engine. I notice my flybar is bent so I'm replacing that. I will be converting her to flybarless system during fall. Other wise I haven't really flown it around yet. Still need to break the engine in. Here are the equipment that I'm using.
Engine: Os 50 Hyper
Muffler: Outrage 55 Evo <------- Going to change it
Cyclic Servo: hitec hs-5945mg
Throttle: Hitec hs-5945
Tail Servo: Futaba S9254 Digital
Receiver Battery: Gens Ace 2500 Mah 2S1P 25C
Regulator: Undecided
Radio: Futaba T8fg Super
Receiver: Frsky TFR8S 8 Channel receiver
Canopy: Notice the first picture? It's the stock canopy I replaced it with
Fusuno Sunset Fiberglass Airbrush Canopy 3D Frenzy 50 FUC FZ501
3D Frenzy Competition Features:
Strong and lightweight G-10 side frames
Three point metal mainshaft bearing mounts
Metal main blade grips
Strong A-Arm style CNC machined elevator linkage
CNC machined aluminum engine mounting block
Push-pull linkages on all cyclic servos
Forward mount engine for easy glow plug access
120 CCPM swashplate 140 available with optional JSS-1634 arms
Front mounted radio mounting frame
Low maintenance belt driven tail
Easily removed, vibration-isolated fuel tank
Pre-painted white plastic canopy with decals
Specifications:
Type: .50 size glow powered competition 3D helicopter
Control System: 120 CCPM (140 with optional JSS-1634 arms)
Length: 1240mm
Height: 430mm
Width: 150mm
Gear Ratio: 8.5-8.6:1:4.64/4.67
Pinion Gear: 10T
Main Gear: 85T, 86T
Main Rotor Diameter: 1342mm - 1362mm
Tail Rotor Diameter: 238mm
Main Rotor Length: 600 - 610mm
Approximate RTF Weight: 3680g
jcervantes11 is offline Find More Posts by jcervantes11
For Sale tz v2 frenzy 50 for sale or trade 101stAB Aircraft - Electric - Helis (FS/W) 4 Mar 20, 2012 09:29 PM
For Sale JS TZ .50 V2 Frenzy NEW Kit - PRICE DROP !!!!! Lenny7118 Aircraft - Fuel - Helis (FS/W) 5 Sep 24, 2011 09:50 AM
Question JS Models TZ-.50 Frenzy ApachePilot Fuel Heli Talk 16 Apr 01, 2010 07:19 PM
For Sale PRICE DROP!!! Almost New! JS Model TZ-50 Frenzy 3D V2 for sale RTF $615.00!! T3beatz Aircraft - Fuel - Helis (FS/W) 0 Jul 20, 2009 12:46 AM
For Sale JS Models TZ V2 3d Frenzy... F/S... A.R.T.F.... Tradhunt Aircraft - Fuel - Helis (FS/W) 0 Mar 04, 2009 10:12 PM
