Old Feb 24, 2003, 11:09 AM
Bone Breaker
Lammergier's Avatar
Dallas , Texas, United States
Joined Oct 2002
How do the servos mount on the slow stick?
I have the gws naro servos.
does the servo arm go on top of the plastic mount and the servo underneath?
Lammergier is offline Find More Posts by Lammergier
Old Feb 24, 2003, 11:43 AM
Joined Sep 2002
There are two plastic servo "brackets."
You slide them apart on the fuse, the distance required to allow your servos to fit with the mounting holes on top of the bracket arms. Secure them using the mounting screws that came with your servos. One screw on each servo end, screwed into each of the brackets. One servo on each side of the fuse - saddlebag fashion.
Sierra Gold
sierra-gold is offline Find More Posts by sierra-gold
Old Feb 24, 2003, 11:58 AM
jimsp's Avatar
Sayre,PA
Joined Sep 2002
Here is what mine look like. I also used the DuBro connectors to make it easier to adjust the servo position.
jimsp is offline Find More Posts by jimsp
Old Feb 24, 2003, 12:05 PM
Profiled Interfractionalist
William A's Avatar
Tacoma,WA USA
Joined Jun 2001
Who carries those DuBro connectors ?
Are those the smallest available of that type ?
William A is online now Find More Posts by William A
Old Feb 24, 2003, 12:25 PM
plane crazy
av8rOC's Avatar
Northport, NY
Joined Dec 2002
You can find those Dubro 'EZ' connectors at any LHS and any hobby store online, they are a must have for any hobbiest using servos!
I believe the min EZ connectors are the smallest they make and are appropriate for parkflyers.
-Sean
av8rOC is offline Find More Posts by av8rOC
Old Feb 24, 2003, 08:40 PM
Silent Flight
daveWCO's Avatar
Tucson, AZ USA
Joined Oct 2002
Connectors
Todd's Model's has the connectors. Great shipping time, too.
http://www.toddsmodels.com/index2.htm
DaveWCO
daveWCO is offline Find More Posts by daveWCO
Is this battery config. hard to mount on a Slow Stick? Jason Paul Parkflyers 0 Apr 16, 2005 11:09 PM
How do you people destroy the Slow STick?? ssyed Beginner Training Area (Aircraft-Electric) 27 Aug 21, 2004 12:45 AM
How do I unwarp foam (stock slow stick) wing? seftonde Beginner Training Area (Aircraft-Electric) 5 Jun 29, 2004 12:30 AM
How to fix wing damage on a Slow Stick. LBM Electric Plane Talk 3 Jun 11, 2003 06:47 PM
how do you mount on trailing edge Bruinjess Sport Planes 5 Jul 10, 2001 02:22 AM
