Old Mar 16, 2002, 03:35 PM
Houston, Texas US
Joined Jan 2002
Hornet swash flying saucer
I have completed a portion of assembly on my Hornet to a point where I wanted to test under power my gear meshes and vibrations.
Chassis assembled, boom on with tail rotor mechanics, everything on rotor head except main blades, motor, esc, rec, batts.
When I power it up it runs real smoothly, good gear meshes, paddles nise and straight and NO vibrations. The thing that bothers me is the swashplate oscilates like a flying saucer, if you will...does not induse vibration, just oscilates. Bare in mind the servos are not hooked up. Also my hornet has the fuel tubing over the shaft and then the spacer that would normally be glued
riding on the top bearing. The main gear mesh is preloaded in by the fuel tubing.
After long story,..why is the swash oscilating? and is it okay that it does at this assembly point?
Mike Giles
Mike Giles is offline Find More Posts by Mike Giles
Old Mar 16, 2002, 04:06 PM
U.K.
Joined Nov 2000
When you say your servos are not hooked up, do you mean not plugged into the rx. or not connected to the servos by the pushrods?
Regards,
Trevor.
trevorjw_uk is offline Find More Posts by trevorjw_uk
Old Mar 16, 2002, 08:09 PM
Houston, Texas US
Joined Jan 2002
Trevor,
Not mechanically connected
Old Mar 16, 2002, 08:24 PM
U.K.
Joined Nov 2000
Link your servos up, adjust the links so that s/plate is at 90o to the shaft when viewed from the front and side. Make sure the paddles are parallel to each other. Make sure all the links are perfectly free. - Go fly!
The "flying saucer" behaviour of the s/plate is perfectly normal if it is not connected to the servos.
Regards,
Trevor.
Old Mar 16, 2002, 08:29 PM
Houston, Texas US
Joined Jan 2002
Trevor,
I am not being a smart A$$ but I thought it was, I wanted to be sure before going further...thank you for your help.
F18 Hornet Not Flying well mitc99kd Electric Ducted Fan Jet Talk 10 Apr 07, 2002 07:50 PM
20 flights on my Hornet and still flying smooth. JStory Electric Heli Talk 8 Feb 16, 2002 01:39 AM
$69.00 R/C Flying Saucer Acer Electric Plane Talk 3 Dec 04, 2001 07:59 AM
wowwee top secret flying saucer? anthonyryan Electric Plane Talk 4 Oct 18, 2001 06:20 PM
Hirobo 3 rotors Flying Saucer GWS4CEO Electric Heli Talk 2 Oct 14, 2001 03:25 PM
