Old Oct 13, 2012, 12:14 AM
bimmerland's Avatar
United States, NC, Cary
Joined Nov 2011
Parkzone motor mounts what's the difference
Just finished putting together my parkzone spitfire when I noticed the motor mount was cracked. The listed part number is pkz5728 and my lhs is out but the had a pkz4428 so I bought it. When comparing mounts could not see the difference other than some cosmetic differences. Can anybody enlighten me on this thanks.
http://www.horizonhobby.com/products...ni-cub-PKZ5728
http://www.horizonhobby.com/products...orsair-PKZ4428
bimmerland is online now Find More Posts by bimmerland
Old Oct 13, 2012, 05:12 PM
Lou
United States, VA, Waynesboro
Joined Dec 2005
That cosmetic difference may be for strength. The PKZ5728 is for the Spitfire and the Spitfire uses a stronger/larger/more powerful 15 sized motor. The PKZ4428 is for the T-28 which uses a so-so powerful 480 motor.
Proceed with caution as a undersized/weak motor mount may cause the motor to depart the plane, taking part of the nose with it. The posible destruction lies not in the pull force against the firewall but in the torque force against the mount itself. The mount could shear at the plate that the motor is bolted onto and thus ripping the motor and part of the nose assembly from the plane.
If you do not feel the cosmetic difference is significant enough to warrant any gain of strength between the two mounts, then use the T-28 mount.
Lou is offline Find More Posts by Lou
Old Oct 13, 2012, 05:30 PM
bimmerland's Avatar
Joined Nov 2011
Thanks for the info. Is this from your experience, technical knowledge or personal opinion.
Old Oct 13, 2012, 05:42 PM
Lou
Joined Dec 2005
I once owned the T-28 and am familiar with it. I did go to ParkZone and Horizon and looked up the specs for both mounts ( there is basically none ) and looked to see what planes they were used in.
Seeing what the planes are for each mount I then saw that each plane used a different 'size' motor. Understanding glow/gas and electric motors the way I do I then extropolated that the unknown cosmetic differences (which are unknown to me) but known to you, may be due to the different size motor that each mount is intended for.
However, also knowing quite well that manufacturers and vendors sometimes play with the part number and appearance of an item, due to marketing or a change in a part supplier, that if the cosmetic difference where only slight and would not add any significant strength to the mount, then either mount would probably work in your plane.
You could ask in the PZ Spitfire thread, someone there could give you a definitive answer.
http://www.rcgroups.com/forums/showthread.php?t=1463636
Discussion Difference between parkzone and eflite motors? Coot83 Electric Plane Talk 10 Jul 30, 2012 06:21 PM
Help! Looking to get 6s batteries, what's the difference between 6s and 6s1P jasper7821 Batteries and Chargers 4 May 15, 2012 07:32 PM
Question What's the difference between discharge rate and voltage? Kevinfred Batteries and Chargers 14 Apr 15, 2012 03:10 AM
Discussion What's the difference between a Hexa and Y-6 copter characteristics? BenHayat Multirotor Talk 10 Mar 31, 2012 09:52 PM
Engine mounting- Upright? Upside down? 45 degree? What's the difference? t_predator90 Engines 3 Dec 27, 2003 10:38 AM
