Old Jul 20, 2012, 11:39 PM
Joined Feb 2008
3000kv blue wonder 24g
I just purchased a 3000kv BW motor. All the data I have seen for this motor is on a 2s. However, I have seen where people have used a 3s and I was wondering if it would work with out blowing motor. I don't have any 2s but i have several 3s 850mAh batteries. Seems like I have people use 4x? props on 3s. Any ideas?
computerman021 is offline Find More Posts by computerman021
Old Jul 21, 2012, 12:08 AM
Standing Athwart History
roo_ster's Avatar
United States, TX, Dallas
Joined Mar 2011
Find the product on the hobby king website, something like "hextronic 3000kv" might work in a search. The comment thread below is chock full of such data.
Off the top of my head, I recall folks running APC4.75x4.75 props and some daring souls running 5x5 props on 3S. YMMV.
Good luck.
roo_ster is offline Find More Posts by roo_ster
Old Jul 21, 2012, 06:42 AM
Canadian Bacon
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Use a wattmeter and, as long as you don't go over the amp rating of the motor you should be good to go. Pick the prop to get the proper amps.
Gord.
flypaper 2 is online now Find More Posts by flypaper 2
Old Jul 21, 2012, 08:32 AM
Jack
USA, ME, Ellsworth
Joined May 2008
Run it up in static testing doing shorter runs and checking for heat. When you get to the point where you cannot keep your finger on the area where the windings and bearing tube are you are pretty close to the safe limit.
Depending on what you want to do in flight, sometimes you can user time limited burst of full throttle and then back off a click to cool it down between bursts. But if you need continuous maximum throttle, test until you find the throttle setting that does not cook the motor.
And keep an eye on the ESC and battery temperature too as you test.
If you want to pursue speed on the 2730 motors there is a ton of info here on doing that. If you look at Truglodite's blog page there are links to a lot of the good info and spreadsheets with a lot of the details. It covers about all of the generations and colors of the blue/red/silver/etc. wonder motors.
Here is one link from Trug's blog page that gives an idea as to how to get more speed out of some of the various 2730 motors:
http://www.rcgroups.com/forums/showthread.php?t=737144
The spreadsheets he has there (you can see them with the free OpenOffice Calc software) has all of the details on winding and even the battery sizes, props, and the like.
Jack
jackerbes is offline Find More Posts by jackerbes
Old Jan 06, 2013, 04:59 AM
FPV Dealer,Getting People High
Johnnymeg's Avatar
United States, CA, Arcadia
Joined Sep 2011
You can run a GWS 5043 prop no problem. Use a 18-20 amp esc and your golden.
Johnnymeg is online now Find More Posts by Johnnymeg
Discussion Replacing shaft on Blue Wonder 24g hextronix trooper8 Power Systems 1 Mar 26, 2010 10:18 PM
Sold Silver(blue) Wonder 1700kv 24g Motors!! xtremeRCpilot Aircraft - Electric - Power Systems (FS/W) 3 Nov 23, 2009 01:54 PM
Discussion UH's 24g Blue wonder, Threaded shaft Butch777 Power Systems 2 Jan 04, 2009 10:35 PM
Sold 24g Blue Wonder Ultralight Aircraft - Electric - Power Systems (FS/W) 1 May 09, 2008 08:16 AM
Discussion UH's 24g Blue wonder and TP's 9g ESC Butch777 Power Systems 1 Sep 08, 2007 04:11 PM
