Old Apr 07, 2014, 02:51 PM
p901P901's Avatar
United States, CA, Lancaster
Joined Jan 2009
Help!
Pulse on battery power
On a YEP 100 amp I am seeing a pulse on the battery terminals that is just about the same rate as the timing set on the controller.
At first I thought I was seeing the FET switching then since it was similar with the clock pulse , this could be what I am seeing. The pulse stays at the same frequency during acceleration but the amplitude changes from about 1 v p-p to about 2v p-p.
Could this be just a problem with one phase?
p901P901 is offline Find More Posts by p901P901
Old Apr 07, 2014, 04:38 PM
We want... Information!
Bruce Abbott's Avatar
Hastings, New Zealand
Joined Jan 2001
Looks like PWM switching noise. Why do you think it's a problem?
Bruce Abbott is offline Find More Posts by Bruce Abbott
Old Apr 07, 2014, 05:02 PM
p901P901's Avatar
Joined Jan 2009
It just seemed odd that I would see this waveform on the battery side.
I was looking to see if there was a noise problem with these ESC's. I seen this and the next to see if there is a filtration problem with the controller voltage rails. It just seemed odd that I would see this waveform on the battery with some extra .1uF caps installed.
Bruce could you check out to see if I am getting it right on the YEP 150's http://www.rcgroups.com/forums/showp...&postcount=193. report 193 to 250
Old Apr 08, 2014, 01:19 AM
Joined Jan 2001
Depending on the load it could be quite normal.
In the other thread you say that your setup can exceed 150A static. Your scope image is too small to see clearly, but the waveform appears to show a step of about 0.5V on the rising and falling edges. Your ESC has two Rubycon ZLH 470uF 35V smoothing cps, right? If you were running part throttle and the motor current was 50A, then each cap was passing ~25A peak and must have an ESR of about 20 milliohms (0.5V/25A).
According their specs those caps have a maximum ESR of 28 milliohms, so it would seem that they are working correctly. To reduce the ripple voltage you simply need to add more caps.
The ESC already has almost 1000uF across the battery leads, so another 0.1uF won't make a perceptible difference.
Discussion Need Advice on Selecting Battery for Charger Power Supply! myerss17 Batteries and Chargers 8 Jul 24, 2014 01:56 AM
Discussion KK2.1 powers on w/ battery, not ESC??? LawyerFrank Multirotor Talk 9 Feb 04, 2014 03:44 PM
Discussion Blade cx2 Looses power after one minute on 5 batteries all fully charged cadcyg Coaxial Helicopters 4 Oct 06, 2013 09:03 PM
Discussion Low power on bigger C battery? cvianna Multirotor Power Systems 1 Sep 24, 2013 04:43 AM
Pul Pull On Scratch Built, Any ideas? Gonflyin01 Parkflyers 1 Jan 23, 2002 03:12 PM
