Old Feb 07, 2004, 06:02 PM
LB
Guest
n/a Posts
Newbie Priming Nitro Engine
Hi People,
I have a Kyosho Inferno Sports and I have a question about priming the
engine. THe manual states that you should "remove the air cleaner" and place
2 or 3 drops of fuel straight into the carbi venturi.
I would MUCH prefer to be able to mount the air filter more permanently (ie
with a zip tie) but is there some other way to prime the engine? There is no
"push pump" mounted on the tank.
Is there some other way to start the engine without pulling the air filter
off?
aGrateful for any suggestions!
MIKE
Old Feb 07, 2004, 11:39 PM
Toronto
Joined Nov 2003
You can place you finger tip on the exhaust exit and then crank the engine over a couple times, just keep an eye on the fuel as it comes through the fuel line and maybe give it a couple extra after it gets to the carb.
solo2guy is offline Find More Posts by solo2guy
Old Feb 08, 2004, 03:01 AM
Mark Stevens
Guest
n/a Posts
Re: Newbie Priming Nitro Engine
"LB" <transam(remove this to reply)@netspace.net.au> wrote in message
news:c03kis$2si3$1@otis.netspace.net.au...
> Hi People,
place
(ie
no
> off?
> MIKE
My nephews car does not have an air filter on it for general running (it
does have one but he doesn't use it) priming via the venturi works everytime
for him, even his mates are jealous at how quickly and how often he gets his
car started compared to theirs...the other way is to take the gowplug out
and prime that way but it is a lot more fiddly and time consuming.
My nephews car does have an air filter but it is easily removed and replaced
for priming.
Regards.......Mark
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.577 / Virus Database: 366 - Release Date: 03/02/2004
24" Crackerbox w/ .15 nitro engine RTR Sawyer692 Boats (FS/W) 2 Jun 06, 2003 03:50 PM
