Old Feb 18, 2013, 02:57 AM
United Kingdom, England, Exeter
Joined Feb 2012
Rc boat advice for camera platform
I am looking to build a rc boat with a small camera mounted on the top and bottom that can rotate. What would you recommend the best shape of hull to get the best stability.
The camera will probably be a couple of go pros.
Dan
dan_d_diver is offline Find More Posts by dan_d_diver
Old Feb 18, 2013, 04:36 AM
Spreckels Lake, GGP, SF, CA
craig_c's Avatar
USA, CA, San Francisco
Joined Apr 2007
Given the requirements of movement a camera platform would have, probably a varient of an Ship Docking Module (SDM) with dual Azipod drives. When properly controlled the dual azipod drive of an SDM will allow you to move in any direction. You might have to scale up a bit, but the ideas under the waterline should do the job. I've been looking at this design for a while as a camera platform, but for much heavier camera systems so I'm looking a a much larger unit than would be required for a GoPro.
Also, you'll need to actively stabilize the camera mount itself with active gimbals and sensors, probably adapting something from the flyboys and their hexacopter camera platforms. Also, if necessary, mount a small first person video (FPV) camera coaxially with the GoPro so you have an active aiming system for your images.
To counteract wave motion a bit and stabilize the entire camera platform, a fair bit of ballast weight set on the bottom at a long piece of pipe descending from the bottom of the hull would probably be helpful as well.
http://www.rcgroups.com/forums/showthread.php?t=1416005
http://www.rcgroups.com/forums/showthread.php?t=551258
http://www.rcgroups.com/forums/showthread.php?t=1686585
http://www.rcgroups.com/forums/showthread.php?t=1710828
http://www.rcgroups.com/forums/showthread.php?t=1763876
craig_c is offline Find More Posts by craig_c
Old Feb 18, 2013, 04:39 AM
NeverAgainVolunteerYourse lf
nick_75au's Avatar
Australia, QLD, Regents Park
Joined Mar 2007
Sailboat hull with keel
nick_75au is offline Find More Posts by nick_75au
Old Feb 18, 2013, 04:57 AM
Blackpool, Lancs
Joined Feb 2006
Or a wide catamaran with weighted fins.
mfr02 is offline Find More Posts by mfr02
Old Feb 18, 2013, 10:39 AM
Sea Dragon-Lover
Umi_Ryuzuki's Avatar
PDX, OR
Joined Dec 2002
Also building a Pan and tilt platform mount for your cameras would also be handy.
These could also be gyro stabilized if you want to invest in some additional accessories.
PAN TILT - unit, hobbyking.com (0 min 33 sec)
Umi_Ryuzuki is online now Find More Posts by Umi_Ryuzuki
Old Feb 18, 2013, 02:03 PM
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
What type of filming? Commercial or just for fun?
Gyro stabilized, blah blah is a lot of money. If you are getting paid for your video it may be worth it.
If you just want video for personal use or club use, then a stable boat with a tilt/pan camera mount will give you all the motion you need. But in my experience, the tilt is not needed.
If you mount a camera solid, you will have to maneuver the model to film your subject. Depth perception becomes an issue.
With a camera mounted on a pan base, the model boat can be left to float stationary while you pan the camera to follow your subject. And of course you can also motor along while panning.
http://www.servocity.com/html/spt100...lt_system.html
http://www.servocity.com/html/ddp125_standard_pan.html
Kmot is offline Find More Posts by Kmot
Old Feb 18, 2013, 02:43 PM
Joined Feb 2012
The filming is for filming wildlife. Filming sharks, seals and turtles.
I will be buildings a pan and tilt head. For the deck, and underwater.
Do most good waterproof serves work in the sea submerged, as sea water get everywhere.!
Old Feb 18, 2013, 02:49 PM
Joined Feb 2012
Any particular brand. Recommend for a cat hull. Or some drawing I can get for free.
Old Feb 18, 2013, 05:09 PM
craig_c's Avatar
Joined Apr 2007
It needn't be pretty - if you go cat, maybe a either a SWATH or hydroairy type design using formed Styrofoam blocks with a coat of epoxy and glass and rigid plastic pipe structure would do. A simple platform for electronics packages and the camera mounts would probably be enough. You could probably also bury a fair amount of the electronics in the foam sponsons to keep the center of gravity as deep as possible.
As you probably guessed, I don't really think there's any Commercial Off The Shelf (COTS) solution for this project as I suspect that you are looking at a more pro-grade end work product vis--vis the images / video. Might be a product here in and of itself in the camera platform.
Old Feb 18, 2013, 05:10 PM
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
This sounds like much more than a hobby grade project.
Waterproof servos are indeed waterproof. But the connectors will be attacked by salt water. You will need to be sure all your connector contacts are gold plated.
Also, the waterproof servos are designed for splash water, and puddles. Not sure what type of depth/pressure ratings they have but I would imagine it to be rather shallow.
Have you seen the Thunder Tiger SB-1 submarine? It is designed as a camera platform for the GoPro camers in particular.
http://www.tiger.com.tw/product/5220-F.html
Old Feb 18, 2013, 05:50 PM
craig_c's Avatar
Joined Apr 2007
The model warship guys have had good luck with dipping their electronics in a waterproofing solution (can't remember name) and sealing their servos with silicone gels.
Mike's Subworks might have parts etc., that would fit the bill
Old Feb 18, 2013, 06:52 PM
JOHN SCALE BOAT's Avatar
United States, PA, Slatington
Joined Feb 2007
My recommendation would be a basic towboat hull. Maximum load for size of the hull. Very stable and maneuverable with twin screws. In the picture of the cabin you see a single camera. If you you are using several GoPros I would have a cover for the hull opening and mount the pan tilt mounts to it.
JOHN SCALE BOAT is offline Find More Posts by JOHN SCALE BOAT
Old Feb 18, 2013, 09:21 PM
CaptCB's Avatar
United States, CA, Orange County
Joined Aug 2011
I would use a med. sized barge, self ballasting with water. Then use a push boat like John recamended. That way you could more easy keep the r/c electronics dry. I have run my 16'' log tug in the open inner harbor, in San Francisco bay. I have run my 36'' Thompson Trawler in the main channel, in the LA side of the LA/LB harbor. Probably couldn't run in the LA harbor these days, as there are even restrictions on where you can run real boats. CaptCB
CaptCB is offline Find More Posts by CaptCB
Old Feb 19, 2013, 04:06 AM
Joined Feb 2012
I have experience with planes, but boats are another thing!
Now I need to find some plans. Should I go for a glass hill or wood?
Old Feb 19, 2013, 12:59 PM
Blackpool, Lancs
Joined Feb 2006
I think most of them sail in fresh water - model submarine technology might be more appropriate. Thanks for reminding me of SWATH, craig. It was what I had in mind but just couldn't think of the name. Agreed that the chances of anything being commercially available are slender.
I feel that the chance of plans is a bit slender, as well. You could be really starting from scratch, and need to think outside the regular box. Depending on the size you envisage, a good start might be your local B&Q, looking at drainpipes in the builders yard section.
Help! New to RC Boats; Needs Advice for Drive Line old_dude Dock Talk 7 Aug 25, 2008 02:39 PM
Discussion Advice for a Novice Picking His First Gas Powered RC Boat mkockler Racing Boats - Internal Combustion 2 Jun 10, 2007 07:37 PM
New Product RC Hot Air Balloon Camera Platform for sale... hergibear Aerial Photography 1 Aug 26, 2006 03:11 PM
Help! r/c boat camera platform zane mathias Dock Talk 4 Feb 21, 2006 11:07 AM
