Old Mar 17, 2003, 02:54 PM
broom driver
Barnsley, Gods own Yorkshire, Uk
Joined Mar 2001
Samba 36 52 Vs hacker b40 FAI
Does anybody know if the kontronic samba 36 52 fits in a avionik D99. (I have read the web page but I can't get the sizes as the site link comes up wrong).
If the samba does fit in a avionik D99 does anyone know how it compares to the hacker b40 FAI motor.
Is the carbon can on the hacker really of any detectable benefit eg if you are a good pilot would you get better results spending else where as there is not that much of a noticeable differance between a b40 FAI or a b40 long 6 turn.
has anyone any quantifiable information on the best esc/ motor for a club / sport flier who may want to compete.
DanC is offline Find More Posts by DanC
Old Mar 17, 2003, 03:04 PM
Caution:Makes sharp left turns
Troy's Avatar
United States, CA, Lake Forest
Joined Feb 1999
My understanding of the B40-FAI is that it is an in-between size of the Hacker motors. The carbon case will be lighter and sometimes 5 grams can make a difference for surface laoding issues, not so much performance.
For the Samba, they do not have this motor ready for production yet. You would have to contact Motor Mike for more info.
For controllers, I have used both the Kontronik 3SL-70FAI and the Jeti Hacker Master-77. Both have been very reliable.
Troy is offline Find More Posts by Troy
Old Mar 17, 2003, 03:07 PM
Pylon freak
Paulus's Avatar
Rijnsburg,the Netherlands
Joined Jun 2000
The samba is 36 mm thick. I don't know how large the avionik nose is but I'm afraid it won't fit.
Paul
Paulus is offline Find More Posts by Paulus
Old Mar 17, 2003, 09:49 PM
Stanton, CA, USA
Joined Dec 2000
I had an old Avionik D99 made in 2000, I could put 1406 Pylon (36 mm diameter) but I donít know about newer one.
Kiho is offline Find More Posts by Kiho
Old Mar 18, 2003, 11:24 AM
Troy's Avatar
Joined Feb 1999
The "newer" small nose version won't fit it. The original nose version (I have two) will fit the Samba or Aveox 14 series.
Old Mar 24, 2003, 11:46 AM
plinse's Avatar
Baden Baden, Germany
Joined Feb 2001
Samba 36-52:
RPM/V : 5200
diameter: 36mm
length: 45mm
mounting flange diameter: 13mm
shaft diameter: 5mm
weight: 160gr
typical efficiency: >85%
max. efficiency: >90%
Eike
My Homepage
plinse is offline Find More Posts by plinse
Hacker B40 FAI F5F 10 cell carbon case motor. shelby Electric Sailplanes 7 Feb 15, 2011 11:51 AM
Mega 22/20/2 vs Hacker B40? Steph280 Power Systems 2 Sep 02, 2003 02:54 PM
Hacker B40 FAI? Doc Data Power Systems 2 Jun 18, 2003 09:44 AM
Hacker B40 FAI F5F +6.7:1 and controller Dan Rubin Aircraft - Electric - Airplanes (FS/W) 2 May 04, 2003 08:48 AM
For Sale...Hacker b40 FAI & Shulz future controller MarkChinery Aircraft - Electric - Airplanes (FS/W) 6 Feb 26, 2003 05:06 PM
