You can't just let the tail drag in the water either. The wings must be kept from touching. Someone posted recently about some cheap foam floats being available. Install them like two main gear... Hmmm, come to think of it the parents in law have a small attached lake, now I want to do it too! |
OK found the video of the EasyStar off water. Worth a look.
http://www.rcmovie.de/video/7e80aa226d13ff9dd04a |
AJ |
Also, if you buy an EZ* from Amazon, you will still have to buy a Brushless motor and ESC and LiPo somewhere else to just have a plane that is similar to the Sky Surfer. That will drive up the total cost to twice the cost of the EZ* and then some. You are not comparing apples to apples. AJ |
AJ |
Also do you thoroughly glue them together as best you can? |
2. No. I don't glue them specifically because I want them to flex and "share" the load when it gets extreme. AJ |
AJ, I work with Carbon Fiber composites engineers where carbon fiber parts are designed and made all day long. You really want to glue the two tubes together. That's what gives them the strength of the added wall thickness. Bill |
Latest blog entry: Eagletree Guardian vs. Eagletree Vector
Gorilla glue? Foam Tac? CA? Welders? What's best?
Using Foam Tac for hinges -
Thanks again to everybody for their comments getting my Bixler going. Took her out to the field tonight, and she flies great...
I've got a GoPro on order which should arrive in the next few days... Here's the camera mount I am going on for it... Any comments? http://www.ilovefpv.com/2011/06/star...vening-flying/ |
For Sale | Cyber Sky Parachute (Sky Surfer) | shv2sail | Aircraft - Electric - Airplanes (FS/W) | 8 | Oct 10, 2020 07:56 PM |
Discussion | Banana Hobby Sky Surfer Problems | cavy92 | Electric Plane Talk | 59 | Mar 23, 2016 08:10 PM |
Discussion | Sky Surfer | nickwayne11c | Electric Plane Talk | 15 | Nov 18, 2011 03:36 PM |
Question | Sky Surfer LiPo mod, help... | Freight Dog | Electric Power Systems | 0 | Aug 17, 2006 01:45 PM |
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? | tekforce | Micro Helis | 4 | Feb 08, 2004 06:28 PM |
