Old Oct 06, 2014, 02:15 PM
Add1ct3dd's Avatar
United Kingdom, England, Worcester
Joined May 2010
Question
What prop to use?
Hey,
So I've got my SkyFun - and all is good and well, until I asked my friend to launch it - naturally he launched it straight up even though I said forwards - anyway moral of the story is don't allow your friends to launch, they break propellers :P
Right so here's my setup:
NTM 28-36 2700kv Motor
Turnigy Plush 60A ESC
4s 2650mah Nano-Tech 35-70C (better C coming tomorrow).
Anyway - I ran a 5x5 TGS Sport prop and it ran perfect, though the motor + esc were completely cold, so that would suggest I may be able to go a tiny bit bigger?
I'm looking to replace the prop and came across the Graupner SPEED CAM ones, they seem to be highly recommended so I think I'll go for them, but struggling on size!
I wondered for a start what people think the max size prop I can run is? I aim for speed with this plane, so short bursts of fun is all good .
Looking at the props I can get made by Graupner there's 2 sizes - either a 4.7x4.7 or a 5.2x5.2 (or a 5.5x4.3) - just wondering if the 5.2 is ok, or if that extra 0.2 on both measurements will over amp the esc or not?
Any guidances as to how to actually work this stuff out would be much appreciated I'm not sure which of the 3 props would be best to go for!
Matt
Add1ct3dd is online now Find More Posts by Add1ct3dd
Old Oct 06, 2014, 03:07 PM
Letchworth, Great Britain (UK)
Joined Jul 2004
Not all props, motors, and props are exactly the same, even if they're same make, model, and size. So, even if someone does advise that a certain brand prop of a certain size is good for them, you need to verify it with a wattmeter on your setup if you want to be sure you're not going to over-amp your motor or ESC.
abenn is offline Find More Posts by abenn
Old Oct 06, 2014, 03:32 PM
Add1ct3dd's Avatar
Joined May 2010
OK that's a good point, I'll get all 3 and test them out - I presume start from lowest and work my way up?
Old Oct 06, 2014, 03:42 PM
Joined Jul 2004
If 5x5 was good, 5.2x5.2 might be the best starting point because, all else being equal, more pitch gives you more speed, which you say you want.
You don't have to start with the smallest, for you can gradually open your throttle while watching the meter, and shut it down if it begins to go too high.
Old Oct 06, 2014, 05:56 PM
Add1ct3dd's Avatar
Joined May 2010
Went for all 3 anyway - if the 5.5x4.3 is no use, that can go on my EFX Racer :]
Also ordered a wattmeter - it's been a long time coming, but just another tool in the ever increasing collection (8 years worth of RC stuff).
Cheers for the help, will go with it and see what's what .
Old Oct 08, 2014, 12:41 PM
Add1ct3dd's Avatar
Joined May 2010
Hey guys, following on from this got some results
4.7x4.7 = 54A on the bench
5.2x5.2 = 72A on the bench
5.5x4.3 = 72A on the bench.
Now, I know the Plush 60A will allow for 80A burst - so presume my 72A is fine, but for how long can I burst? Is it long enough to do a speed run, say 5-10 seconds? I also presume these numbers would be slightly lower in the air as you're moving, and have good cooling (won't lower numbers, but would help).
The motor and ESC are both situated on a SkyFun, and are in the path of air - so both have good cooling .
Also, which prop would give the greatest top speed, 2 of them are 72A, and I'm not sure how the numbers differentiate speed vs thrust.
I guess ideally a 5x5 would still be the best prop, its likely to sit around 60-62A judging at the figures, which was my original prop - but I wanted to test some quality props and sadly Graupner don't do a 5x5 SPEED CAM prop - any suggestions for good quality 5x5's?
Old Oct 08, 2014, 02:48 PM
Joined Jul 2004
Don't just consider the ESC -- you need to remember that your motor is only rated for 50A continuous, or 595 watts, whichever is greater (that's about 40A if you're using a 4S pack)
Personally, I would stick with the 4.7x4.7, and just check that your motor is not too hot at the end of a flight.
All else being equal, larger diameter gives you more thrust, and more pitch gives you more speed.
Old Oct 08, 2014, 02:49 PM
Add1ct3dd's Avatar
Joined May 2010
That's true, cheers for the info
I'll run the 4.7x4.7 first, see how it goes - I remember being on the 5x5 the motor and esc were both stone cold (but then it was a cheaper prop so may not have been as efficient), so we'll go from there .
Help! What motors and props to use? k5nwz Multirotor Power Systems 1 Sep 27, 2014 02:15 PM
Help! What prop should I use for higher altitude flying? Flyboy68 Power Systems 5 Jul 22, 2014 02:31 PM
Discussion What Props Should I Use??? lasicm Multirotor Talk 0 Apr 25, 2014 02:16 PM
Discussion What props to use with 900kv sunny sky? ProfitOfDoom Multirotor Power Systems 9 Nov 01, 2013 11:43 PM
Discussion Maloney 100 16-6 prop what prop should I use? vic gensberg Engines 1 Jun 10, 2013 09:35 AM
