Old Jul 29, 2014, 04:15 PM
Joined Jul 2013
Bigger prop on a stock tfl smash shark with tfl 120a esc?
Hi.
I run a smash shark with tfl electronics and got some questions about tuning.
The esc is 120a and it comes with 6mm bullet connector, it have a small battery at the top that is connected to the esc battery cable.
This esc comes in hard plastic, anyone that have experience with this esc?
Motor is a stock 2070kv.
When i run this on 4s with stock metal prop that is 38mm the esc and motor keeps cool, the only thing that is hot is this little battery pack on top of esc that is connected to the battery plugs.
Im impressed about this esc after reading a lot negative of the tfl 125a that is in a rubber plasic thing outside.
I have run it about 17 times now and it works great.
Could i run with bigger prop on this esc or is the stock 38mm maximum size?
I could try out 40,42, 44mm and bigger props.
If i go from 38 to a 40 or 42 prop, how mutch faster would it be? Dont want to overprop it
I got another question, if i buy a 180A esc, could i run this motor on 5s?
Thanks for answers!
waterprooof is offline Find More Posts by waterprooof
Old Jul 29, 2014, 04:22 PM
Joined Oct 2011
Don't think its a battery pack on top of your ESC...Its a capacitor bank.
2070Kv on 5S is do-able, but not recommended as you are approaching 40,000 RPM.
How hot does the cap bank get?
dobydog6507 is online now Find More Posts by dobydog6507
Old Jul 30, 2014, 01:40 AM
Joined Jul 2013
Could you tell me what it is? Never see one like this before.
Its hot to touch, guess about 45-50celsius but i could take with me a temp gun next time i run it and it shows farenheit and celsius
Old Jul 30, 2014, 03:28 AM
speed-boater
rbachmann's Avatar
Stuttgart, Germany
Joined Apr 2010
Show some pics.
Otherwise it is difficult to discuss.
Roland
rbachmann is online now Find More Posts by rbachmann
Old Jul 30, 2014, 09:25 AM
Joined Oct 2011
https://www.google.ca/search?q=tfl+e...banks&tbm=isch
Old Jul 30, 2014, 02:15 PM
Joined Jul 2013
Here is a pics of the esc.
Could i go from 38mm to 40mm? Would it make difference?
Old Jul 30, 2014, 02:34 PM
Joined Jul 2013
Double post.
Old Jul 30, 2014, 02:49 PM
bostong's Avatar
Danmark, Sjælland, Sorø
Joined May 2011
Dont do 5s - I think you would burn your esc.
Do a 2min full throttle run with stock prop, then get it to shore and measure temp.
Do the same with 40 - if temps are still in the green, try with bigger props till temps go to high.
(Make sure to check temps on esc/motor prior to first run, and then make sure to start run with bigger props at approximately same temp.)
bostong is offline Find More Posts by bostong
speed-boater
rbachmann's Avatar
Stuttgart, Germany
Joined Apr 2010
This is indeed a capacitor bank and no battery.
Never seen the ESC before. May be another expert knows that part. Is there any label on the ESC?
Roland
Old Jul 30, 2014, 03:08 PM
Joined Jul 2013
Yes i dont want to try 5s, but maby want a bigger prop and i have no idea how mutch faster it would be with a 40 when 38 is stock, it runs cool now so i havnt take any temp of it but thank you for the tip.
No label on it, its made by tfl and its a 120A, thats everything i know.
It have lipo cutoff and count the battery with beeps, works great.
But the battery looking thing on the top get hot to touch when i run it hard over long time.
Old Jul 30, 2014, 03:45 PM
Boaters are nice people.
Sneek, Netherlands.
Joined May 2004
If the caps bank are the only capacitors on the ESC (none soldered directly onto the circuitboard) the relative thin wiring may be the cause for the heat.
See if you can shorten them as much as possible, measure if that makes a difference.
Regards, Jan.
pompebled is offline Find More Posts by pompebled
Old Aug 02, 2014, 03:33 PM
Joined Jul 2013
Yes i would try to do that, thanks for the tip..
But what are a cap bank? Other esc dosnt have this outside?
Old Aug 07, 2014, 05:05 AM
Joined Jul 2013
The cap bank is 58c/136,40f and the esc was about 40c /104f maby littlebit lower.
This was taken after 10 minutes of runtime, and i almost run full trottle the last two minutes.
136f sounds littlebit high, how high could the cap bank be before it blows?
Old Aug 07, 2014, 07:42 AM
speed-boater
rbachmann's Avatar
Stuttgart, Germany
Joined Apr 2010
Normal (good) capacitors work up to a maximum temperature between 80°C and 105 °C.
It always depends on the quality of the cap. But not exceeding 80°C should work for all.
Old Aug 07, 2014, 07:59 AM
Joined Jul 2013
Thank you for the answer, since 58c is ok then i would try the 40mm prop with two more mm than stock before it draw to mutch amp
Do you have any idea how mutch more speed 2mm bigger prop would give? Or maby i should go for a bigger prop to get more speed? Like a 42 or 44, the stock is 38.
Discussion Info on TFL's Apparition ESC and motor? mostwanted Dock Talk 0 Jul 26, 2014 04:47 PM
Discussion Tfl smash shark question stock boat rtr waterprooof Racing Boats - Electric 8 Jun 19, 2014 12:46 AM
Discussion H/K ,TFL Smash Shark.??? madracer Racing Boats - Electric 2 Dec 15, 2013 01:49 AM
Help! Tarot 650 Phantom Swap flips & crashes with bigger prop adventureseen Scratchbuilt Multirotors 13 Nov 17, 2013 08:38 PM
For Sale Motrolfly 120A ESC with BEC Mock707 Aircraft - Electric - Power Systems (FS/W) 1 Oct 07, 2013 12:42 AM
