Old Jan 03, 2014, 12:06 AM
Crashing into the sky!
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
New 28mm Planetary Gearbox - Mega PG28-3.0KW
Got my hands on a new toy from the Czech republic, its nice
I dont have many of the details, and the battery in my verniers just died, but will update this thread when I get them all
28mm diameter with a 6mm shaft, 6:1 Ratio, 48g dry
Its quite a clever, well machined, and very tough looking little unit!
All the planets use roller bearings, with steel cages. The output shaft is supported by 2 bearings, the rear one being a thrust type bearing. Similar to the Neu/Leomotion P29 it uses a pinion machined into the motors shaft, so will need to be purchased with a motor. At least there wont be the problem of busting pinions off shafts
Unlike the KPG Box, there is no washer that retains the planetary gears, the adapter plates covers that job. The forward housing of the gearbox threads into the adapter plate, but then is secured with 2 grubs screws through the forward plate, making for a much more mechanically secured box. No "Jesus" tape needed! Also much less swearing when dissasembly..
Also unlike many other boxes, the adapter plate is raised/cutout around the cooling holes in the motors forward cap! Yet the whole assembly is still around 2mm shorter than a KPG25. Clever.
Without having tested it yet, Im confident it'll take pretty much whatever a 28mm motor can throw at it!
jackosmeister is offline Find More Posts by jackosmeister
Old Jan 03, 2014, 12:12 AM
200mph +
sykotic's Avatar
New Zealand, Manawatu-Wanganui, Palmerston North
Joined Sep 2010
Looks good. Interested to know the exact diameter across the box where the "grip" marks are cut in.
Any idea of the type/quality of the lube it comes with?
sykotic is offline Find More Posts by sykotic
Old Jan 03, 2014, 12:26 AM
Auckland NZ
Joined Aug 2007
28.3mm in the knurled section. Infront of that it tapers down to around 25mm. The lube that came with it was a light machine oil, similar to the kontroniks factory stuff.
Old Jan 03, 2014, 12:43 AM
War is over (if you want it)
vespa's Avatar
Thousand Oaks, CA
Joined Mar 2004
Wow! Looks like a great design! But how did you get the ring gear out? And what keeps the planets from hitting the motor screws?
vespa is online now Find More Posts by vespa
Old Jan 03, 2014, 12:53 AM
Auckland NZ
Joined Aug 2007
Ring gear is secured as the adapter plate is screwed into the forward housing, and the grub screws are tightened. It sits slightly proud of the housing so is clamped between the two. With the adapter plate unscrewed, the shaft/planets and ring gear can all come apart with finger pressure
The aft bearing housing is the only part that might require some tooling to dissemble, as it appears to be a press fit onto the (beefy!) shaft
The screws that attach the adapter plate to motor are countersunk, and slightly over countersunk, so they clear the planets safely.
Old Jan 03, 2014, 06:46 AM
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
Looks great!
Just wondering a little about the reduction ratio. I count 8T pinion, 16T planets and 40T housing. Doesn't that ad up to a 5:1 ratio and not 6:1? ((16/8) x (40/16) = 2 x 2.5 = 5)
Arcteryxxx is offline Find More Posts by Arcteryxxx
Old Jan 03, 2014, 09:10 AM
GryphonRCU's Avatar
United States, CA, SF
Joined Mar 2008
After quick research on google:
( 40 + 8 ) / 8 = 6
Nice pictures Jacko.
G.
GryphonRCU is offline Find More Posts by GryphonRCU
Old Jan 03, 2014, 09:22 AM
Arcteryxxx's Avatar
Joined Feb 2010
( 40 + 8 ) / 8 = 6
G.
Cheers!
Yes, you're right
http://woodgears.ca/gear/planetary.html
Old Jan 03, 2014, 11:02 AM
Hemet California
Joined Jul 2009
Very Nice, It is great to have more options for equipment
D.English is offline Find More Posts by D.English
Old Jan 03, 2014, 11:10 AM
One Idiot is plenty...
Dbox's Avatar
United States, OR, Portland
Joined Jun 2005
I really like the gap between gear and motor.
Motor cooling holes aren't plugged .
I hope magic word "China" not written on the bearings?
Yuri
Dbox is offline Find More Posts by Dbox
Old Jan 03, 2014, 02:26 PM
Auckland NZ
Joined Aug 2007
Im glad you guys sorted out the ratio! I was dreading having to wake up this morning and count teeth! You are far to observant Arcteryxxx
Bearings feel good Yuri, no mention of China anywhere
Old Jan 03, 2014, 03:07 PM
The Sequel
mustflynow2's Avatar
Australia, VIC
Joined Sep 2011
Yuri
VMGM? Model motors/ axi use as well from cz, on the case is printed Eko-Program and name f.hendrych, Frantesik Hendrych, and cell for Cz. Seems website is under construction maybe.
http://www.eko-program.cz/kontakt/index_en.html
I have noticed other ratio/size from icare before on front of axi but no experience
So give it hell Jacko, will watch
mustflynow2 is online now Find More Posts by mustflynow2
Old Jan 03, 2014, 03:09 PM
What is Highspeed ?
Rolf D.'s Avatar
Germany, BY, Bergen
Joined Feb 2011
I ordered it with a 4:1 Ratio and waiting for answer if I can get it with 5:1
Rolf D. is offline Find More Posts by Rolf D.
Old Jan 03, 2014, 03:20 PM
Auckland NZ
Joined Aug 2007
Remember youll probably need a shaft with a pinion machined into it even for the lower ratios. Mega will sell them matched to motors for around 88euro.
Old Jan 03, 2014, 03:35 PM
Arcteryxxx's Avatar
Joined Feb 2010
My big question is: many of us know how Dan rates his motors (=very conservative). When the GB rating is 3.0kW, how much can it actually take?
4kW? 5kW? Did I hear 6kW????
For Sale Zagi Tazz motor with planetary gearbox $25 shipped CONUS paypal only john-doe Aircraft - Electric - Power Systems (FS/W) 2 Jan 05, 2014 05:42 AM
Sold Mega 22/45/3 and planetary gearbox 3.75 smurf Aircraft - Electric - Power Systems (FS/W) 9 Jul 15, 2008 09:48 AM
Excessively Noisy Mega 16/15/3 with planetary gearbox llrelease Power Systems 15 Jan 02, 2006 11:46 AM
FS: Aveox 27/13/3 and 4, 27/26/1.5 and Mega 22/20/2, planetary gearboxes kyril Aircraft - Electric - Airplanes (FS/W) 3 Oct 16, 2003 06:56 PM
Planetary gearbox for Mega 16/15/3 mkirsch1 Power Systems 21 Jan 17, 2003 05:33 PM
