Old Dec 08, 2001, 11:16 AM
flyinryan's Avatar
Joined Sep 2001
smoke system how to
Looking for specific info on how to put a smoke system on my Cap 232 with a O.S. surpass .91 four stroke. Such as where do you inject the fuel carb or exhaust, does it need preheating ?, what do you use to inject it and what makes the most dense smoke. Thanks for your help
flyinryan is offline Find More Posts by flyinryan
Old Dec 08, 2001, 02:03 PM
Worcester, MA.
Joined Nov 2001
Ryan,
A couple manufacturers make smoke systems for our slimers. (Yeah, I admit it, I do the "dirty" deed occasionally too. )
Smoke oil is definately injected into the muffler. Many engines require that the oil be pre-heated. This (I think) is usually a coil wrapped around the muffler that the oil passes through before being injected.
I know Perry makes components like smoke oil pumps and servo controlled valves. I remember complete systems that someone puts out, I even think it's called a "Simple Smoke System", but can't remember who!
Dave Brown comes to mind for some reason, but...??? If it comes to me I'll write again.
Good Luck!
Dennis-
DBCherry is offline Find More Posts by DBCherry
Old Dec 09, 2001, 02:51 PM
Bill Glover's Avatar
United Kingdom, Bracknell
Joined Nov 2000
Not sure that you'll get a good smoke setup with a 4 stroke, I've only seen it done with big 2 strokes (mostly petrol rather than glow). Good info from Dennis, if you can buy a commercial system then do .. things like the pump rate (or tank pressure) vs injector size will take a lot of experimentation otherwise.
Bill Glover is online now Find More Posts by Bill Glover
Old Dec 09, 2001, 04:50 PM
Daren's Avatar
Los Alamos, NM, USofA
Joined Nov 2000
I used the Simple Smoke System by TME (Tejera Microsystems Engineering, Inc. - http://www.geocities.com/tmenet/products.htm) with great success. It took a minor bit of tweaking to get the flow right (smoke on, see how much smoke, turn up or down the flow, try again), but once I did it was instant on, instant off.
I do recommend range checking as the old pump I have does put out a bit of RF noise. I can't speak for the new System II. They also offer the Simple Smoke Secrets booklet with purchase which will walk you through all of the do's and don'ts.
BTW, the hotter an engine's exhaust, the more smoke it will produce. The hottest to least hot in the following order; two-stroke gas, four-stroke glow, then two-stroke glow.
Good luck,
Daren
Daren is offline Find More Posts by Daren
Discussion cold vapor generator? (smoke system) How? Accu157 Dock Talk 17 Aug 09, 2007 12:52 PM
Smoke system for 280 sized motors. Ahawk Parkflyers 6 Nov 17, 2002 06:05 PM
Smoke System for Parkflyers? fat matt Parkflyers 2 Oct 05, 2002 04:34 PM
Smoke system pn2k Electric Plane Talk 1 Aug 25, 2002 10:20 PM
Smoke System for Zagi or TV ???? Captain Carlton Foamies (Kits) 4 May 25, 2002 01:00 PM
