Old May 15, 2013, 01:27 PM
we dont NEED roads!
AcroFPV's Avatar
United States, CA, Rocklin
Joined Aug 2012
Thats a good looking build. Do you know how heavy the frame was without electronics?
My wooden H frame came in just under 3lbs... it obviously was way too heavy. So I scrapped the idea and moved everything to a spider FPV frame. The build log is here: http://www.rcgroups.com/forums/showthread.php?t=1804472
I am starting to run out of room, and im not very happy with the vibrations I am getting from cheap plastic arms. I am thinking of re-visiting the H-frame, but with lightweight materials.
AcroFPV is offline Find More Posts by AcroFPV
Old May 15, 2013, 01:34 PM
Retired Flyer
United States, FL, Boynton Beach
Joined Nov 2011
The frame less electronics is very light, instead of running wood strips from end to end I sandwiched a piece of epp foam and it prevents flex in the middle. With a 3300 mah battery it hovers at less than half throttle.
I also have that same spider frame, didn't like the bouncing gimbal. Way to much vibration and bounce. But I did modify it and hard mounted it to my dji 450 cradled in a home made lexan holder with memory foam, and it works perfect.
Attached pic of Gimbal with Lexan cradle and memory foam
floridabiker is offline Find More Posts by floridabiker
Old May 16, 2013, 02:13 AM
eyesonsky's Avatar
Switzerland
Joined Jul 2010
Great to see all of these DIY, thanks for sharing.
Originally Posted by floridabiker View Post
Here is some pics of my latest H Quad
980KV Sunnysky's with 11x4.7 props lift this thing with ease, and Naza keeps it steady as a rock for Aerial Videos.
I use a piece of memory foam under camera mount for anti-vibration.
Camera housing is for the Sony Action Cam HDR-as10
Nice build welcome to your new QuadH.
Have fun.
eyesonsky is offline Find More Posts by eyesonsky
Discussion need help build my first quad for long range fpv adam88888 Multirotor Talk 25 Sep 02, 2014 11:22 PM
Build Log Building an H-Quad floridabiker Scratchbuilt Multirotors 8 Apr 16, 2013 02:46 PM
Help! Is this an ESC / Motor issue? (First Quad build) TEDious Multirotor Talk 4 Mar 20, 2013 12:59 PM
