Old Feb 18, 2012, 03:12 AM
Cabledawg1's Avatar
USA, VA, Newport News
Joined Jan 2010
Is this diagram correct?
Ill be running 10S...2 x 5S 3000mah packs. Im using a Castle BEC. Its good up to 6S. Can I pull voltage from just one pack as configured in the picture? I am trying to eliminate a switch I would need between 1 battery and the BEC.
In the pic, the arming plug, mounted on the outside, would power up the RX and the ESC.
Cabledawg1 is offline Find More Posts by Cabledawg1
Old Feb 18, 2012, 05:55 AM
A man with too many toys
United States
Joined Feb 2001
That looks ok to me.
Or you could get a CC BEC Pro and hook it up in parallel with the ESC. That would be a better solution.
RC Man is offline Find More Posts by RC Man
Old Feb 18, 2012, 08:43 AM
Electric Helis is my game
MrMel's Avatar
Lidingo, Sweden
Joined Feb 2005
No, that is NOT correct, do not hook it up like that
http://www.castlecreations.com/produ...multicell.html
the "master negative" , i.e. where the negative goes to the ESC is where you have to have your negative cable to BEC.
MrMel is offline Find More Posts by MrMel
Old Feb 18, 2012, 08:59 AM
Cabledawg1's Avatar
Joined Jan 2010
I have this question in the Castle thread and it was a no go. Posted a new pic, but hadnt gotten an answer yet....this should work ...right? It shouldnt matter that the arming plug is on the negative....right?....is there a better way to do this?
Old Feb 18, 2012, 09:05 AM
MrMel's Avatar
Lidingo, Sweden
Joined Feb 2005
Yes, that will work much better!
Discussion Is this diagram correct? Cabledawg1 Power Systems 6 Feb 18, 2012 02:23 PM
Suggestion What do I need to do to correct this injustice?... tdmosstristate Site Suggestions / Complaints 1 Aug 13, 2011 10:01 AM
Help! Is this correct motor, ESC and batterysetup? djsong121 Power Systems 3 Jun 01, 2011 07:27 AM
Question is this the correct way Doushiyou12 Power Systems 9 Mar 20, 2011 01:53 AM
Discussion Spektrum Receiver Bind Diagram, Correct? sonicserve Radios 4 Jul 25, 2008 10:24 PM
