Old Apr 13, 2012, 03:46 AM
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
What about a twin pusher instead? Leaves more space for batteries...
Arcteryxxx is offline Find More Posts by Arcteryxxx
Old Apr 13, 2012, 09:30 PM
gchrisgo34's Avatar
United States, GA, Jonesboro
Joined Nov 2010
has anyone ever put retracts on this plane?
gchrisgo34 is offline Find More Posts by gchrisgo34
Old Apr 13, 2012, 10:16 PM
Trammellc2001's Avatar
United States, OK, Claremore
Joined Nov 2010
Description: Yep. Here's mine.
Trammellc2001 is offline Find More Posts by Trammellc2001
Old Apr 14, 2012, 05:47 AM
United States, FL, West Melbourne
Joined May 2011
Trimming question
High power and slow she dives, High speed she climbs. I can't see an obvious way to shim the motor (stock). I understand why this happens and I know it is a choice of trimming one or the other . If someone has a fix please let me know.
Rickflaguy is online now Find More Posts by Rickflaguy
Old Apr 14, 2012, 06:43 AM
Why the dirt on the wings?
moparmyway's Avatar
New York
Joined Jan 2009
1. Trim for wide open throttle
2. Inspect elevon position with power to servos
3. If elevons are slightly up, tighten the front mount screws to squish foam and give you more thrust angle, then fly it again and trim for wide open throttle
4. If elevons are slightly down, tighten the rear mount screws to squish some foam which will lessen your thrust angle, then fly it again and trim for wide open throttle
Repeat process untill you dont have an immediate pitch change with throttle input, and untill your elevons are basically neutral with the wing, not in the airstream, and streamlined with the fuse.
moparmyway is offline Find More Posts by moparmyway
Old Apr 14, 2012, 10:03 AM
Joined May 2011
Just guessing but some up thrust might help in the launch too?
Old Apr 14, 2012, 12:58 PM
moparmyway's Avatar
New York
Joined Jan 2009
It depends on the transmitter you are using and the type of throw you preferr
Old Apr 14, 2012, 02:11 PM
gchrisgo34's Avatar
Joined Nov 2010
Originally Posted by Trammellc2001 View Post
Attachment 4781953Yep. Here's mine.
looks like you did a really good job installing those. struts and everything, very nice.
Old Apr 14, 2012, 03:03 PM
rimripper's Avatar
Alberta,Canada
Joined Nov 2009
If your talking motor thrust ange being the up thrust,no,it needs to be straight.
rimripper is offline Find More Posts by rimripper
Old Apr 14, 2012, 03:52 PM
Arcteryxxx's Avatar
Joined Feb 2010
No, but a "launch mode" with positive elevator input does wonders
Old Apr 14, 2012, 04:24 PM
Joined May 2011
Guess it's time to go back to the dx7 manual. Launch mode?
Old Apr 14, 2012, 07:04 PM
Paducah, KY
Joined Jan 2010
Some time ago I tried a lot of different HK stuff to see what works and what doesn't in a Stryker. HK pours out motors, ESCs and stuff and I have only tried a small fraction of the combos available.
From the 20+ setups I have tried these are my favorite components:
Motor: http://www.hobbyking.com/hobbyking/s...dProduct=11181
ESC:http://www.hobbyking.com/hobbyking/s...arehouse_.html
Run it with a separate BEC like the one from CC or use the http://www.hobbyking.com/hobbyking/s...23v_Input.html either drawing power from the main battery or from something like this: http://www.hobbyking.com/hobbyking/s...arehouse_.html
For mounting the motor you don't wanna get something from HK, but this is the one to get: http://www.customrcparts.com/index.p...ar69foivr8ul91 (together with the brackets of course)
Run the combo with an APC8x6 sport on 4S for incredible climbing performance or with an APC7x8 sport for some 130mph speed runs in a glassed Stryker.
I think this will be about the best you can hope to get from $100 worth of hardware.
Battery size should be no smaller than 4S4000 40C or 5S3000 40C, preferably larger.
How do I know this? I can prove it
The Stryker in the video is a far from perfect specimen, but built strong with CF tubing, glassed all around and sturdy as a armoured truck. AUW was about 1850 grams.
Thanks so much for the info and the links on this. I will be placing an order on these parts Monday morning. When you order the 39mm mount pictured there do you get the brace that goes on the body of the plane itself or do you order that separate on the site. The reason I ask is I've tried finding it on the site and can't so I'm guess it comes with the engine mounts???
Orion
orion13 is offline Find More Posts by orion13
Old Apr 14, 2012, 07:10 PM
Arcteryxxx's Avatar
Joined Feb 2010
Orion
The backets normally comes with the 28 and 36mm kits. Slip Gary (sales@customrcparts.com) a mail and ask if you can get a combo deal on the 39mm + brackets. Should set you back about 40some and be well worth it!!!!
Old Apr 14, 2012, 07:35 PM
rimripper's Avatar
Alberta,Canada
Joined Nov 2009
The dx7 is great,just program a bit of up elevator on your 3 way switch for launching.
Old Apr 15, 2012, 09:05 AM
Too much is just not enough...
Woody_99's Avatar
Joined Jan 2009
This works very well.
I've got just 2-3 mm up elevator, and that does the trick.
Woody_99 is online now Find More Posts by Woody_99
Discussion Parkzone F-27C Stryker That can fly?!? Parkflyers 109 Sep 26, 2012 10:54 PM
Discussion Parkzone's New F-27C Stryker itspat Parkflyers 1 Nov 08, 2011 07:56 PM
Mini-Review F-27C Stryker Review That can fly?!? Parkflyers 27 Jul 29, 2010 08:25 PM
Discussion Parkzone F-27C Stryker 3S 11.1 V Balance Plug WDP Batteries and Chargers 12 Oct 26, 2009 08:44 AM
Discussion Coming soon! F-27C Stryker RTF with lipo and brushless Solcat Electric Plane Talk 0 May 31, 2006 12:34 PM
