Old Dec 27, 2004, 06:45 AM
-mH
Joined Sep 2004
Introducing Fully Complete CNC ZOOM/SHOGUN Ass'y from MicroHeli.com
With extreme precision machining from tolerance of +/-0.002mm, we hope these goodies will bring you the silkest flights you've ever experienced.
Welcome on board!
Andy Le
www.microheli.com
Performance In Style
-mH is offline Find More Posts by -mH
Old Dec 27, 2004, 06:51 AM
CINCINNATI,OHIO - U.S.A.
Joined Nov 2004
Very nice! I will be contacting Wes at Modefo's to get one ordered for sure!
Kevin
CRAZYKEV is offline Find More Posts by CRAZYKEV
Old Dec 27, 2004, 06:55 AM
DeSoto MO
Joined May 2003
Wow, will the tail rotor hub and grips come polished from the factory like that? Or will that be left up to the end user?
Nick_P is offline Find More Posts by Nick_P
Old Dec 27, 2004, 07:56 AM
-mH
Joined Sep 2004
Nick,
All of our products from the smallest parts such as paddle holders to tail rotor all got polished until we can see our face on it. To get to this beautiful image, the products after leaving the machines, are carefully hand textured with sand paper to remove some slightly cosmetic scratch if there is any, then go through hand deburred, then through meticulous hand polishing process, following with cleaning and drying. All have to go through these labour-intensive cleaning and polishing processes to provide the most beautiful surface finishing upgrade parts available. We have almost a dozen of full time employees just for this job . We believe our customers deserve nothing less than the best!
Andy Le
www.microheli.com
Old Dec 27, 2004, 07:59 AM
Joined Nov 2004
Andy,
Just out of curiousity, what is the reason for the two different mounting holes on the grips for the ball link?
Kevin
Old Dec 27, 2004, 08:25 AM
Blade Springs "Rock"
Central Coast, CA
Joined Apr 2004
Originally Posted by CRAZYKEV
Andy,
Kevin
Isn't that for either side placement? On grip fits both sides....????
Just a guess....
G109
Geoffrey109 is offline Find More Posts by Geoffrey109
Old Dec 27, 2004, 08:28 AM
Joined Nov 2004
You are probably correct G109, I should have put a little more thought into it!
Kevin
Old Dec 27, 2004, 09:19 AM
2013 GRAND SPORT CORVETTE
Hoverup's Avatar
Golden Gulf Coast
Joined Jul 2002
The complete T/R is now available. This is good stuff. Great job Andy.
Cheers - Boyd
Hoverup is offline Find More Posts by Hoverup
Old Dec 27, 2004, 09:28 AM
-mH
Joined Sep 2004
Thanks Boyd,
Kevin,
Here is your Blue Output gear V2 - No more spinning!
Andy Le
Old Dec 27, 2004, 09:33 AM
Hoverup's Avatar
Golden Gulf Coast
Joined Jul 2002
Another issue resolved. Man you guys are on top of things.
Old Dec 27, 2004, 09:34 AM
Joined Nov 2004
Lookin' good Andy! Glad you guys incorperated the collar man! Did you guys mess around with the idea of making the crown gear a little larger in diameter to get a wider tooth? It looks a little bigger, but that could be me?
Also, I see you guys have made some more blue bevel gears. Did you guys find a quicker way to machine them?
Kevin
Old Dec 27, 2004, 10:01 AM
-mH
Joined Sep 2004
not yet Kevin,
Just keep going... one by one...
Andy
Old Dec 27, 2004, 10:13 AM
Joined Nov 2004
Andy,
No complaints here buddy! I was amazed at how fast you guys came up with the V2 crown gear. Microheli is very responsive to customer input and acts very quickly!
Thanks Andy!
Kevin
Old Dec 27, 2004, 10:31 AM
Joined Nov 2003
Can the blue slider and bladeholders with ball links be used on a hornet 2 stock or microheli gearbox.
I know the H2 stock gearbox doesn't have the possibility to use a ball link pitch slider but there are ways around that with some CA etc....
Reason for me asking is the fact that i like ball links more then the H2 solution with the 1 mm pins.
mattijs321 is offline Find More Posts by mattijs321
Old Dec 27, 2004, 10:43 AM
-mH
Joined Sep 2004
This is the Hornet tail pitch slider using ball link
Andy
+++Introducing first fully CNC tail system for T-REX from MicroHeli.com+++ -mH Mini Helis 4 May 02, 2005 01:46 AM
MicroHeli Zoom/Shogun CNC goodies Hoverup Mini Helis 39 Dec 30, 2004 09:47 AM
Zoom/Shogun 400 MD 500 D and E scale bodies from darthdrk Hoverup Mini Helis 6 Oct 18, 2004 10:17 AM
Zoom/Shogun beltdrive coming from Heliup.com Hoverup Mini Helis 5 Sep 18, 2004 12:46 PM
CNC Aluminum Pitch Lever Joint for the Zoom/Shogun mdttb Mini Helis 1 Jul 28, 2004 08:56 PM
