Old Jul 06, 2014, 12:40 PM
Old Timer
The Kiwi's Avatar
USA, TX, San Antonio
Joined Jun 2010
I was never enamored of the TufStrand type. These are the lines that I used with .29 to .35 sport / stunt planes:
http://brodak.com/control-line-parts...-x-2-x-60.html
They used to only cost about $3.00 a set when I was using them up the fastest!
Some people suggest that .018s are better for sport, however, in my experience, they are more likely to pick up kinks than the 015s.
Kiwi
The Kiwi is offline Find More Posts by The Kiwi
Old Jul 06, 2014, 01:04 PM
I've seen an airplane flown on TufStrand, then flown of 015 cables. The flier was ecstatic at how much better it flew on cables.
Jim Thomerson is online now Find More Posts by Jim Thomerson
Old Jul 07, 2014, 08:06 AM
Canada, ON, Cottam
Joined Jan 2012
I haven't tried my Tuffstrand lines, but they measure about .018" and are kind of oval or squarish. I would think they would have more drag. I may try them sometime though. I have a couple 1,000 ft rolls of the .015 and .018" to use up.
aspeed is offline Find More Posts by aspeed
Old Jul 17, 2014, 05:32 PM
United States, MN, Eagan
Joined Jul 2013
Thank Guy's
I made a stupid mistake, the push rod was in the hole closest to the elevator not the hole farthest out from the elevator
My misunderstanding..I have made a new rudder and will try the new handle as well.
Hopping to get out this weekend if the weather hold out.
jbonice is online now Find More Posts by jbonice
Old Jul 19, 2014, 11:47 AM
Joined Sep 2011
65 ft is too long... I have a Buster with a Flash 35 on it and fly it with 59' eye to eye lines, with a McCoy we used to fly with 57.5" lines.. I built a plane that had too much elevator and it was a pain, I went to my line spacing an got it to around 2.5" before the plane settled down. I really need to open it up and fix it. I never liked the wooden elevator horn in the CG Kits.. they were too short. The elevator is 1/8" if I remember, I went to 3/16th on my Buster..
JJ
JC Johnson is offline Find More Posts by JC Johnson
Old Aug 15, 2014, 04:28 PM
Joined Jul 2013
A big thank you guy's
I was able to get out last weekend and do my first flight...Woohooo she fly's
Old Aug 16, 2014, 02:43 AM
stuntflyr's Avatar
Los Angeles
Joined Jun 2010
.015x57 lines, horn on outside hole, you should have a fighting chance. Hard point handle at around 3 inches line spacing, you'll be even better, you have gotten a lot of good help here. Good luck.
Chris...
stuntflyr is offline Find More Posts by stuntflyr
Old Aug 16, 2014, 08:14 AM
Joined Jul 2013
Thanks Chris
I did purchase a new handle with adjustable line spacing.
Old Aug 24, 2014, 06:39 PM
army_eod's Avatar
United States, PA, Windsor
Joined Jan 2010
Tufstrand is horrible. I tried it and threw it in the trash. It is bad news. It is draggy and when you do stunts and the lines touch each other it is like they are glued together. Makes for very bad handling. Never use that junk.
army_eod is offline Find More Posts by army_eod
Old Aug 26, 2014, 11:18 AM
F2D Pilot/Mechanic
Bob Mears's Avatar
United States, TX, Lubbock
Joined Dec 2011
Wow! thats a lot of trouble to figure out the cg. Just reach under the wings with you fingers about 25% back of the center wing chord. It needs to balance there. Make adjustments to get it there and it will fly. If it doesnt, you have other problems.
Bob Mears is offline Find More Posts by Bob Mears
Old Aug 27, 2014, 03:12 AM
army_eod's Avatar
Joined Jan 2010
LOL..combat pilot. You don't have a tail so you can never be tail heavy.
Old Aug 27, 2014, 07:34 PM
Joined Jul 2013
I agree Army
Tufstrand is horrible..I ended up junking it all.
Old Aug 28, 2014, 10:27 AM
F2D Pilot/Mechanic
Bob Mears's Avatar
Joined Dec 2011
You are correct. Instead of tail heavy we have "O CRAP!!!!WHERE DID IT GO!!!!"
Slowstick Question: Adjusting Elevator and Rudder Travel? kizzy Beginner Training Area (Aircraft-Electric) 9 Oct 13, 2005 10:52 AM
Question Unwanted elevator travel GaryO Radios 6 May 22, 2005 11:40 PM
Independent elevator/aileron travel with elevon mix on JR2610 (JR6102 in U.S.) AntonL Radios 4 Nov 15, 2004 12:49 AM
Elevator travel for 3D aerobatics Steven9026 Sport Planes 6 Feb 07, 2002 08:19 AM
Flea Elevator Travel StructuresGuy High Performance 2 Oct 20, 2001 12:06 PM
