Old Mar 07, 2014, 07:10 AM
Joined Dec 2013
Jet turbine Hydro formula hull
Hi
I just put a 24lb wren turbine into a fibreglass hydro boat hull and have discovered a slight, but important problem:
Water gets into the air intake
The hull has an open air inlet which faces forwards, it was not a drama when the boat had a small piston engine, but now it has a jet engine any water that gets splashed up onto the air intake goes straight into the engine intake
I tried simply blocking the front air intake of the boat but then the engine rapidly got too hot.
I thought about some sort of splash guard but the amount of suction at the turbine intake is so much at higher revs that is still sucks in the water that is deflected around the intake.
I have seen videos of turbine rc boats with completely enclosed engine compartments and I was wondering why these do not heat up because of lack of air flow to the intake?
Any ideas of how to solve my problem
Cheers
Muddypaw (Australia)
muddypaw is offline Find More Posts by muddypaw
Old Mar 25, 2014, 05:59 PM
United States, NC, Hendersonville
Joined May 2013
I worked on this a while ago, never really got a great result and moved to other projects. I added a snorkel just like the real boats have. It worked ok , has long has the front spoilers were in a neutral location. I still believe a water jacket can be made to work but the heat kept giving me leaks in a very simple setup.
I am not a robot is offline Find More Posts by I am not a robot
Discussion jet turbine rc hydro water problem muddypaw Racing Boats - Internal Combustion 2 Jan 11, 2014 07:46 PM
Sold Élan Thrust Jet. 27 lb Jet Cat Turbin. $ 3500.00 HUGH DURDEN Aircraft - Fuel - Jets (FS/W) 0 Dec 13, 2013 06:38 PM
Discussion TURBINE jet with smoke kenwiesner Flying Wings 0 Nov 19, 2013 10:14 PM
