Old Aug 07, 2013, 11:43 PM
Low rates are for wimps
bwoollia's Avatar
United States, CO, Colorado Springs
Joined May 2008
Build Log
Park Flyer Plastics "1/4" Scale P-40
Man, I gotta say I'm excited about this build. When I discovered the kit on Keith's site I was smitten! There is a build log done by Keith here and another builder has started his own log as well, both in the foam section. I decided it would be appropriate to start my own build log here. This will be a scale project for me!
First off, I think it's important to note that the model isn't quite 1/4 scale. A quick bit of math puts it at 1/4.67 scale, however it's still quite large at 95" wingspan!
I purchased the kit from Park Flyer Plastics, and the CNC parts package with extra foam from Ken's CAD Models.
The short kit from Keith is first class, the vacuum formed parts are of very good quality! Of special note is the great cockpit detail and the huge spinner! There is also a metal spinner backplate and laser cut plywood parts.
I'm starting with the wings. Here are the bottom sheets with the rib and spar locations traced out.
bwoollia is online now Find More Posts by bwoollia
Old Aug 08, 2013, 06:02 AM
United States, VA, Herndon
Joined May 2007
I'll be watching this one...
wilmracer is online now Find More Posts by wilmracer
Old Aug 08, 2013, 07:26 AM
Parkfly Padawan
JForbes's Avatar
United States, PA, Waynesburg
Joined Aug 2011
Subscribed. I've been in a slump on my build the past couple of months, just with "life and a wife" but hope to get back into it soon. I agree 100% on the kit... it is amazing. I have only done the fuse thus far, but if you have any questions, it's still pretty fresh in my mind so I'll try to help out with answers the best that i can. Best of luck.... this plane is going to be awesome!
JForbes is offline Find More Posts by JForbes
Old Aug 08, 2013, 07:49 AM
USA, PA, Westmoreland Co.
Joined Aug 2008
What do you guys plan to use for power? The same motor setup Sparks used?
I'm wondering if it would be possible to do a geared motor setup, which would help turn a scale size 3-blades prop and sound better too, and not like a big electric weed trimmer.
jonquinn is offline Find More Posts by jonquinn
Old Aug 08, 2013, 08:17 AM
Parkfly Padawan
JForbes's Avatar
Joined Aug 2011
I think for mine I will probably go with the Turnigy 50cc electric motor. It was a toss-up between that and the Rimfire for me, but after reading some reviews, I liked the feedback on the Turnigy a little more. Just my opinion and my plan though... I'm not sure about the build in this thread.
Old Aug 08, 2013, 08:21 AM
No Hangar Queens!
Maryland
Joined May 2009
Tuning in. I've seen you do great work in balsa with an Aerodrome RC kit. Lets see what you can do with foam
Willsonman is online now Find More Posts by Willsonman
Old Aug 08, 2013, 08:43 AM
The Hun in the Sun
vonJaerschky's Avatar
Canada, BC, Comox
Joined Nov 2003
Go Brian Go! Can't wait to see this one come together.
vonJaerschky is online now Find More Posts by vonJaerschky
Old Aug 08, 2013, 10:26 AM
No Hangar Queens!
Maryland
Joined May 2009
Hey VonJ! glad you would tune in as well! I'm watching as I have a project in the planning-stage. Peter Rake Bristol F2B but I want to do it out of foam. Looking for possible build techniques. I know Brian can be quite creative so BUILD ON!!
Old Aug 08, 2013, 12:18 PM
ARFs make me BARF
mrittinger's Avatar
United States, MI, Roseville
Joined Dec 2000
Eflite has new large motor as well....
Neat project.
Mark
mrittinger is online now Find More Posts by mrittinger
Old Aug 08, 2013, 03:19 PM
bwoollia's Avatar
Joined May 2008
Neat project.
Mark
Wow, a lot of interest! Welcome guys, I hope I can live up to your expectations.
As far as power is concerned, I did get a good deal on a Scorpion S-5535-160 which is what Keith used in his with the three-bladed prop. I'm going to engineer some ducting to guide cooling air over the motor and out the cowl flaps (which I may make functional). I did consider some other Turnigy options as well:
http://www.hobbyking.com/hobbyking/s...dproduct=18182
http://www.hobbyking.com/hobbyking/s...dproduct=18184
So the plans for this one:
  • Functional Split Flaps
  • Retractable Tailwheel with scale canvas lined interior
  • W/C Stocky Edwards scheme (I used to chat with Stocky at the mess in Comox)
  • Rotary Drive System aileron & rudder (RDS) - I don't want control horns hanging out.
  • Weathering, panel lines, etc
So far I have the motor and retracts in hand. I have to pick up some servos, RDS connections and air control kit before I seal up the wing.
http://www.vintagewings.ca/VintageNe...memorated.aspx
Old Aug 08, 2013, 08:04 PM
ARFs make me BARF
mrittinger's Avatar
Joined Dec 2000
I spoke with a full scale P40 pilot when I designed my 42" P40E fro MAN. He said that there was so much air going in the big scoop that couldn't get out, even with the cowl flaps open, that you could feel the heat down the side of the fuse.
On my model, I had to block off half the scoop to stop the hatch from blowing off, and it was held on with Goldberg hatch clips! Just something to consider.
If I recall, Keith's bird is a P40E, and yours is a "long tail".....might need some mods.
Mark
Old Aug 08, 2013, 09:17 PM
bwoollia's Avatar
Joined May 2008
Mark
I know that Keith had issues with the cowl pushing forward into the spinner as the fuselage overpressurized from the huge intakes! I'll have to let air out where I can, and make sure that hatches and cowls are secure!
I'm not exactly sure what Keith's model is, however the cooling inlet that he put on the side behind the spinner pegs it as a P-40M or N. Now, whether that detail is appropriate for the model is another story! I was really hoping that no-one would point out the model variant issue, you have forced me to deal with it!
Old Aug 08, 2013, 09:26 PM
The Hun in the Sun
Canada, BC, Comox
Joined Nov 2003
We're here to help.
Old Aug 09, 2013, 12:13 AM
D-Rock's Avatar
Phoenix, AZ
Looking forward to seeing this one progress. Any plans on what retracts you will be using? Subscribed
D-Rock
D-Rock is online now Find More Posts by D-Rock
Old Aug 09, 2013, 12:20 AM
bwoollia's Avatar
Joined May 2008
D-Rock
I have a set of Robart 150s.
Off Site P-51 and Corsair and P-40 New in package Robart scale 2 1/4" diamond treaded wheels MiG-3 Reno Rocket Aircraft - Electric - Airplanes (FS/W) 1 May 07, 2013 01:13 AM
Off Site P-51 and Corsair and P-40 New in package Robart scale 2 1/4" diamond treaded wheels MiG-3 Reno Rocket Aircraft - General - Miscellaneous (FS/W) 1 May 07, 2013 01:12 AM
Off Site P-51 and Corsair and P-40 New in package Robart scale 2 1/4" diamond treaded wheels MiG-3 Reno Rocket Aircraft - General - Miscellaneous (FS/W) 1 May 07, 2013 01:09 AM
Off Site P-51 and Corsair and P-40 New in package Robart scale 2 1/4" diamond treaded wheels MiG-3 Reno Rocket Aircraft - Fuel - Airplanes (FS/W) 1 May 07, 2013 01:09 AM
Discussion 1/4 Scale FanFold P-40 plans? joker24458 Foamies (Scratchbuilt) 4 Apr 19, 2013 08:58 PM
