Old Jan 19, 2015, 10:53 PM
Joined Jan 2012
Question
Help with Multiple LiPo charging... s
Hi,
I'm sure this question has been address before but I just want to be sure I'm doing this right.
I have 5 Lipos:
(2) 2000 mah, 2S, 1C, 7.2V
(3) 1700 mah, 2S, 5C, 7.2V
I'm using my icharger 106B+.
How many amps should I be charging at? 9.1 amps ( 2*2 + 1.7 *3 = 9.1) or can I just go 10 amps since the 1700 mah have a 5C charge rate?
Any comments would be appreciative. thanks!
mammothtarm is offline Find More Posts by mammothtarm
Old Jan 23, 2015, 08:26 PM
mCPx
Race Miata's Avatar
Vancouver, Canada
Joined Nov 2004
Depends on IR on each pack and how far off from 1C you don't mind going into each pack.
http://www.helifreak.com/showthread....20#post6304720
Race Miata is offline Find More Posts by Race Miata
Old Jan 23, 2015, 08:56 PM
So. Cal.
A lot of armchair theory (misinformation) in that thread. Enough that it can be disregarded, at least in my experience.
I'd have zero issue charging the resultant 9100mAh pack at 10A but understand that this is slightly over 1C charge rate (~1.1C). This won't create any issues and I've personally been balance charging 1C charge rated packs at up to 3C with my iChargers for many years without ill effect.
Highly recommend that you perform balance charges on each and every charge to maintain proper pack balance and ensure maximum safety.
mrforsyth is online now Find More Posts by mrforsyth
Sold 250 quadcopter bind and fly w/ 4 liop's raamedicva Aircraft - Electric - Multirotor (FS/W) 5 Nov 16, 2014 05:04 PM
Discussion Charging multiple 1S with Hyperion 0606i Joe Perrone Batteries and Chargers 1 Jul 26, 2014 11:18 AM
Discussion Why can I charge multiple parallel connected lipos with the same charger at once? CyberCrash Batteries and Chargers 8 Mar 05, 2014 02:17 PM
Help! Charging multiple 1S lipo's uncledude Batteries and Chargers 2 Jan 08, 2014 06:35 PM
Question Charging multiple mcpx batteries with imax b6 drake29a Batteries and Chargers 4 Sep 20, 2013 10:23 PM
