Old Jan 25, 2015, 03:49 PM
FunN4Lo's Avatar
United States, LA, Baton Rouge
Joined Aug 2014
From the crash post just above.... I have connected to the PC Tarot software. If you look at the video, the camera has the bed spins. Of course normally, the onscreen camera mimics what you do with the GoPro but not now. If I power the gimbal up/down, sometimes I get what you see in the vid. Sometimes it spins on the vertical access, and sometimes it will generally mimic where the GP is positioned for a moment, and then start the spins.
I tried updating the software, flashing the settings, and calibrating the sensor. Nothing changes.
Any ideas
Bed spin Tarot (1 min 4 sec)
FunN4Lo is online now Find More Posts by FunN4Lo
Old Jan 26, 2015, 11:06 AM
Soon to be CrashMasterPhil
Rochester MN
Joined Dec 2007
Try calibrating the Gimbal
Tarot Gimbal Sensor Calibration (3 min 31 sec)
divemasterphil is online now Find More Posts by divemasterphil
Old Jan 26, 2015, 04:48 PM
FunN4Lo's Avatar
Joined Aug 2014
Any ideas
https://www.youtube.com/watch?v=YLKfIl7qJy8
Originally Posted by divemasterphil View Post
Thanks for the follow up. I had already found that vid. But most everything else that I have read says do NOT calibrate the gimbal that way. I shortened my quoted post above, but I did try to calibrate. The camera still has the spins on screen, and does the shimmy-shake chicken dance in real life.
At this point it might not hurt to try to calibrate that way. Any other ideas out there?
Old Jan 26, 2015, 07:49 PM
FunN4Lo's Avatar
Joined Aug 2014
Has anyone had a gimbal with issues and installed one of these that solved the problem?
http://www.hobbyking.com/hobbyking/s...dproduct=44329
Old Jan 26, 2015, 10:57 PM
Rochester MN
Joined Dec 2007
That is the exact replacement board. You can get is USA.
http://www.rangevideo.com/tarot-t-2d...ss-gimbal.html
Or ebay
http://www.ebay.com/sch/i.html?_from...&_sop=15&rt=nc
Old Jan 27, 2015, 06:09 PM
Isle of Man
Joined Apr 2012
Some musings
It seems there is a definite intermittent connection somewhere caused by the crash.
The chicken dance is caused by the controller giving out motor movement instructions that are based on information from the IMU and that is screwed up at the moment, the system is feedback based. It's the same as a new gimbal that's not been programmed before.
The issue may be a loose wire in any connector either motor or IMU as that will cause the above to occur.
You should be able to find it, I've not done it personally but I think you could probably fault find a single axis at a time by unplugging one motor and then seeing if one axis will maintain orientation.
jhkiom is offline Find More Posts by jhkiom
Old Jan 27, 2015, 10:58 PM
FunN4Lo's Avatar
Joined Aug 2014
Originally Posted by jhkiom View Post
Some musings
I found a loose screw on the tilt motor shaft. That axis seams to be fine now. If I pick up the quad and pitch it forward/back all is good. If I roll it at all, the chicken dance starts up. Both axis were causing issues before fixing the screw. So I've isolated the axis. I don't see any other physical issues on the roll axis. I don't see any obvious issues on the control board. I guess I'll take the sensor cover off and see if there is anything obvious there.
I really liked this gimbal before I crashed it. But I have wanted a 3 axis to help with the occasional tail wag in videos. I always assumed Tarot would be coming out with a 3 axis. The 2D has dropped price everywhere. That is often a sign that something new is around the corner. But I have 2 gigs lined up, and I can't wait any longer. So I ordered Feiyu 3 axis.
Once that's installed and operating, I think I'll order that control board kit above. If I get it working, this gimbal can be a back up. Or maybe I'll build a hand held rig.
Old Today, 02:28 PM
Canada, QC, Saguenay
Joined May 2013
Hi, trying to convert this gimbal to 3 axis and I want to extend the cable of the original motors without scrapping the connector. And since I need to plug them in an Alexmos board, I need standard servo connectors. Is this femal connector would work with the one on the motors? Is it the right model?:
http://www.hobbyking.com/hobbyking/s...5pcs_bag_.html
Thanks!
jparchib is online now Find More Posts by jparchib
Old Today, 03:13 PM
Rochester MN
Joined Dec 2007
Try this site. He's got RC connector you can think of.
http://www.hansenhobbies.com/products/connectors/
Thanks!
Old Today, 03:44 PM
Joined May 2013
Yeah but I would need to know hich connector it is. Lots of similar connectors exist it seems. 1mm, 1,25mm, 2mm...
For Sale TAROT ARTF Brushless motor Gimbal by TACOTOY for DJI PHANTOM GOPRO 3 rctaco Aircraft - Electric - Multirotor (FS/W) 28 Jan 23, 2015 05:16 PM
Build Log GoPro Hero 3 Brushless Gimbal (Plywood) Skewp Multirotor Talk 18 Sep 10, 2013 02:36 AM
Sold Brushless ready gimbal for gopro hero 3 hdworld Aircraft - Electric - Multirotor (FS/W) 29 Jul 13, 2013 04:32 AM
For Sale Brushless ready gimbal for gopro hero 3 hdworld Aircraft - Electric - Multirotor (FS/W) 15 May 06, 2013 08:42 AM
Sold Complete Brushless Gimbal Setup for GoPro Hero 2 crd FPV Equipment (FS/W) 2 Apr 28, 2013 11:14 PM
