commercially available, WW has to be the best. It was my first wing (raider) and I built it in 4 hrs.
The holes aren't cut, but the servo holes are pre marked. Battery placement is left up to the builder to help balance without weights. Parts fit great, though the elevons were not pre sanded to 45. Even easier is the "Swift" by a guy in LA. His idea of a "kit" is wings glued together, spar in place, holes cut for RX, batts and servos. You tell him what equipment and he has templates to balace without additional weight. His name is John, and you can get his info at www.rbbreezers.com hope this helps, jim |
Out of all the wing I have ( 2-MSW, TwinSW, SpeedWing 400, Unicorn, Zagnut, Fixx, U-bat, and a few foamies I built myself.
The one that was the easiest to build was the FIXX Glue 2 half together with a motor stick in between, drop your servos in precut holes, install pushrods, put on some tape. I know the FIXX is not as hardy as some of these other planes, but I love mine and I have always been able to fix it after a hard crash. Larry |
Latest blog entry: Grunt
| Thread Tools | |
| Rant Combat Wings XL flying wing (not recommended--build wise anyways) | jnjloo | Slope | 63 | Apr 30, 2007 08:32 PM |
| Discussion Which of Mr. JetSet44 model is easiest to build/fly? | iam | Pusher Prop Jet Models | 20 | Feb 04, 2007 10:01 PM |
| 16/15/3 and CC35; Which Flying wing do I get? | T_MECO | Flying Wings | 8 | Oct 14, 2005 05:48 AM |
| I want to build a small Flying Wing out of Depron? | joystix | Foamies (Kits) | 4 | Aug 17, 2002 09:48 PM |
| Which flying wing reigns supreme in combat right now? | stevenfrancis2000 | Foamies (Kits) | 11 | Jul 09, 2002 01:42 AM |
