Old Feb 21, 2014, 03:14 PM
Essex BOF's Avatar
Joined Sep 2009
"Watts New"
Have now got this model well underway. It started as something to fill my time, not that I did not have anything else to do have 2 new models to assemble.
It has a fuselage based on the Watts Up but there any similarity ceases with a more attractive wing plan form, plus it is much bigger at 3.8 metre span.
I wanted to try and build something to match the current moulded models, or get as near as I could. Wing is all sheet covered, and uses carbon spars on the centre section 1.2 mm thick, with the sheet going over the spars to give clean section. Tips use 1/16 ply spars with carbon web between spars like the Watts Up
The wing as built weighs in at 686 grams but will go up a bit with finishing but pleased with it so far, Fuselage and tail weigh 330 grams, so want to aim for 1.7-1.8 kilo all up, we will see.
A few pictures attached for interest
Essex BOF is offline Find More Posts by Essex BOF
Old Feb 21, 2014, 06:21 PM
Sweden, Stockholm County, Sollentuna
Joined Aug 2010
I look forward to follow your build - I learn a lot by studying what master builders like you have done.
Could you tell us a little bit more about this girl (is a plane a 'she' like boats?)? In the first picture I see neither spoiler, nor ailerons. Am I not looking hard enough, are you going to add them later, or will she be a 'pure' rudder-elevator glider?
/Stefan
SBS_Pilot is online now Find More Posts by SBS_Pilot
Old Feb 21, 2014, 09:05 PM
volare est vivere
ray foley's Avatar
United States, OH, Toledo
Joined Jan 2005
hi there from Toledo
From the name I presume an Epowered fuselage ala the Watts Up. I saw no provision for spoilers nor flaps, so some territory will be needed for landings. Looking forward to more info and photos and of course a maiden flight report.
ciao -rjf
ray foley is offline Find More Posts by ray foley
Old Feb 22, 2014, 05:16 AM
Essex BOF's Avatar
Joined Sep 2009
/Stefan
The flaps & ailerons are yet to be cut out from the wing sections. This is how I have done them in the past, which seems to work out ok, so the model is a 4 servo wing. After cutting out the control surfaces, I rebate the ribs back & then insert a strip of 1/8" balsa using epoxy resin, using weights to maintain the hinge line.
The section is MH30 modded to 2.5% camber, as I find I can build these section reasonably accurately.
Power is to be a Hacker A20-6 4.4 gear box, which I have laying about, which are light. Fuselage has a downward curve built in to give some down thrust.
Old Mar 01, 2014, 11:33 AM
Essex BOF's Avatar
Joined Sep 2009
Some pictures of the fuselage front end
Old Mar 13, 2014, 03:50 AM
Essex BOF's Avatar
Joined Sep 2009
A few more pics. The wings have been glassed underneath, still have to do the top of the wings before cutting out the flaps & ailerons. Hatch now fitted and shaped. The cut outs in the tips are for the movable ends to the ailerons, in the tiplets
Old Mar 20, 2014, 06:52 AM
Essex BOF's Avatar
Joined Sep 2009
Ailerons cut free from wing tips, rebated to take TE
Old Apr 11, 2014, 09:48 AM
Essex BOF's Avatar
Joined Sep 2009
Coming on now, wings glassed and horns mounted on flaps & ailerons, fuselage being painted.
Tail plane pylon mount now retained by hold down screws rather than glueing in place. Make for easier access to servo for the elevator & threading wire through for rudder servo.
Old Apr 18, 2014, 07:18 AM
Essex BOF's Avatar
Joined Sep 2009
Airframe now complete. Very satisfying when you get to this stage from a blank sheet of paper
Old Apr 22, 2014, 04:25 PM
martinh's Avatar
United Kingdom, England, Fleet
Joined Aug 2002
Looks really beautiful. Did you meet your target weight?
Do you publish plans for your designs? Could be just what I'm looking for at a price I can afford
Cheers, martin
martinh is offline Find More Posts by martinh
Old Apr 23, 2014, 04:53 AM
Essex BOF's Avatar
Joined Sep 2009
Cheers, martin
Have not finished installing the radio gear as yet to find out if the target weight will be met. Suspect that it might creep over, we will see.
As to publishing the plans Martin, there is a lot of work in drawing up plans to a standard that is justified in selling them. I do sell some of them, but at the present time as the years fly by feel that I need to spend my life making the most of it.
As I have said before, I do these projects to occupy myself in the winter months.
Most recently I drew up the Fast Wing for the Watts Up, as people wanted it. You can find this on the Watts Up site.
Old Apr 23, 2014, 06:01 AM
United Kingdom, Ilford
Joined Mar 2013
That looks excellent. Where will you be flying it?
mart46 is offline Find More Posts by mart46
Old Apr 23, 2014, 07:24 AM
martinh's Avatar
Joined Aug 2002
Originally Posted by Essex BOF View Post
...feel that I need to spend my life making the most of it.
Sounds like a good plan to me
Martin
Old Apr 23, 2014, 09:00 AM
mhodgson's Avatar
UK, Coventry
Joined Aug 2005
martinh
If you are looking for an esoarer to build you may want to look at this months Quiet & Electric Flight. It has a soarer called the 'Emulator' that may fit your needs.
http://gb.trapletshop.com/emulator-34
mhodgson is offline Find More Posts by mhodgson
Old Apr 23, 2014, 11:12 AM
Essex BOF's Avatar
Joined Sep 2009
I fly at Rettendon or Chelmsford, Essex
Sold BRAND NEW NTM Prop Drive 28-36 3000kv - 755 watts of goodness Left Coast DJ Aircraft - Electric - Power Systems (FS/W) 1 Dec 29, 2013 09:04 PM
Sold 2ea New Hobbyking Watt Meters planebldr Aircraft - Electric - Power Systems (FS/W) 5 Oct 27, 2013 09:31 AM
Sold Watt's Up Watt Meter - Like New Cond whitty7628 Aircraft - General - Miscellaneous (FS/W) 2 Apr 15, 2007 06:31 AM
Wanted I need one or two inrunner brushless, 175 to 225 watt motor, new or like new. himeros Aircraft - Electric - Airplanes (FS/W) 3 Oct 17, 2005 12:51 PM
Do watts in "Watts-per-pound rules" mean "watts in" or "watts out"? wollins Electric Plane Talk 5 Feb 15, 2005 11:51 AM
