Old May 23, 2012, 03:25 PM
More Pile-it than Pilot
mdennis's Avatar
Shawnee, Kansas
Joined Nov 2002
Idea
New landing tape
I decided to make a couple of new landing tapes, but have had poor luck writing on nylon web strap with a permanant marker like a Sharpie or Magic Marker.
I decided to try a fabric paint and it worked out great. The picture below is what it looks like when dry and ready to use. The paint does soak in a little, but not enough that you can't put a different marking on the other side. I marked this side with a point per inch up to 100 points and the other side is marked with a point per 20cm.
The last picture is of the type I used. The craft store had a whole bunch of different colors and brands. I did try a 3D fabric paint and it wanted to run a little like the marker, but not near as bad. The bottle has a really fine tip and you just gently squeeze it to get the paint out in a fine line
mdennis is offline Find More Posts by mdennis
Old May 23, 2012, 06:39 PM
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
Nice wrok. what was your source for the nylon tape?
aeajr is online now Find More Posts by aeajr
Old May 23, 2012, 09:54 PM
mdennis's Avatar
Shawnee, Kansas
Joined Nov 2002
It's just 1" wide nylon webbing. Available on the internet for $.25 to .50 per foot depending on how much you buy.
This particular webbing is from an old landing tape that I had laying around due to its unreadability.
Old May 23, 2012, 09:57 PM
mdennis's Avatar
Shawnee, Kansas
Joined Nov 2002
Duane Beck did send me a link to some that are commercially made by Tom Broeski
http://www.rcgroups.com/forums/showthread.php?t=1644010
They look pretty nice and are $28 + $2 shipping each or $50 for 2 delivered.
Old May 24, 2012, 03:48 AM
Joined Mar 2007
Out of interest, what is a landing tape?
bogbeagle is offline Find More Posts by bogbeagle
Old May 24, 2012, 08:18 AM
LI, New York, USA
Joined Mar 2003
Watch the videos and you will understand. They are used for scoring landings in contests.
LANDING PRACTICE - This is how you get good!
Note that these guys tape their practice, probably so they can review and learn from what they did, to get even better.
Expert and World Champion Daryl Perkins
Desert Landings 3 I2 (8 min 17 sec)
World Class competitor Brendon Beardsley
F3J Landings with Brendon Beardsley.mov (6 min 30 sec)
Old May 24, 2012, 11:24 AM
Jim Deck's Avatar
Valparaiso, IN
Joined Apr 2005
Great landing tape material
Years ago, I made a set of landing tapes from nylon parachute straps as I was tired of skegs ripping up the ones made from lawn chair webbing. They were available in bright red and lasted a long, long time. The supplier even installed grommets for the stakes. Sorry, but I don't have that suppliers name.
Jim Deck is offline Find More Posts by Jim Deck
Old May 24, 2012, 12:05 PM
mdennis's Avatar
Shawnee, Kansas
Joined Nov 2002
You can get Nylon webbing on ebay for about $10 for 10 yards or polypropylene at about $10 for 50 yards. The poly webbing will work just fine.
I folded the end of mine over into thirds, put some stitches around it then put a 1/4" hole grommet in. I just used a standard sewing machine to put the stitches in. I used an old soldering iron to poke the hole. It will melt right through. You can get the grommet at the craft store in a kit with the tool for just a couple of bucks. This small size may be called a large eyelet instead of a grommet.
Old May 24, 2012, 02:03 PM
Joined Mar 2007
Ah, right, I get the idea. Thanks.
Old May 24, 2012, 03:46 PM
Joined Mar 2010
I know it's total overkill, being a 100 footer, but how about this fiberglass tape:
http://www.homedepot.com/Tools-Hardw...&storeId=10051
rtbates is offline Find More Posts by rtbates
Old May 24, 2012, 05:00 PM
mdennis's Avatar
Shawnee, Kansas
Joined Nov 2002
The first 100" should work for a point per inch tape.
Old May 25, 2012, 11:26 AM
LSF303 / AMA Life Member
tkallev's Avatar
USA, IL, Wheeling
Joined Jan 2003
I used these people when I had to make F3J tapes for the LSF a few years ago. Great stuff, won't stretch, takes a grommet well, a lighter will fuse the ends so it won't unravel.
http://www.uscargocontrol.com/Search...500R&x=22&y=12
tkallev is online now Find More Posts by tkallev
Old May 25, 2012, 02:45 PM
AMA 964040
MAP123's Avatar
USA, MA, Worcester
Joined Oct 2008
Wow, 100 feet! You might want to work on your landing technique! Maybe try using spoilers?
MAP123 is offline Find More Posts by MAP123
Old May 25, 2012, 03:00 PM
Woodstock 1's Avatar
Ireland, County Kerry, Kerry
Joined Dec 2005
Lol.
Woodstock 1 is offline Find More Posts by Woodstock 1
Old May 29, 2012, 04:04 PM
Joined Jan 2003
webbing is cheap on ebay - I made a bunch of tapes from this stuff:
http://www.ebay.com/sch/i.html?_nkw=...bing&_osacat=0
Jim
jimsoars is offline Find More Posts by jimsoars
Sold Club Special Landing Tapes tbroeski Aircraft - Sailplanes (FS/W) 2 Oct 20, 2012 08:26 AM
For Sale 100" landing tapes tbroeski Aircraft - Sailplanes (FS/W) 0 May 01, 2012 06:36 AM
Question Where to get landing tape. dougalert Multi Task F3X 4 Apr 20, 2012 05:57 PM
Sold 100" Landing tapes tbroeski Aircraft - Sailplanes (FS/W) 0 Apr 09, 2012 05:26 AM
Discussion Landing Tapes awilmunder Electric Competition Soaring-F5J/ALES/e-Soaring 2 Mar 07, 2012 06:36 PM
