Old Jul 11, 2014, 06:09 PM
Joined Sep 2011
Question
Lx/banana hobby twin 70mm f-22 setup? CG?
Hi guys, I've had my f22 for a while now and I still havnt worked up the courage to take it for a maiden! The reason for this is confusion about correct cg. The reccomended battery is 6s 3600 mah, but I couldn't see a 3600 lasting very long at all and I already have 4000 and 4500 nano-tech packs.. So I set my cg according to the manual, and had to add a fair amount of weight to the back. To compensate for the larger pack.
I have since read on forums that people are using 4000-5000mah packs but no mention of adding weight.
I have also cut out foam to push the pack as far back as possible.
My questions are:
Do I take the weight out and put my packs back in the normal position and hope for the best? (nose heavy)
Do I keep my jet the way I have set it up as per the manual reccomended cg? (Balances on cg)
What cg have people used, if any different to standard?
Throws on elevators?
To use thrust vector or not to use it?
I can't find much negative info on flight characteristics, so if you have anything negative, please speak up so I know what to expect! Thanks in advance
vtssuper6 is offline Find More Posts by vtssuper6
Old Jul 11, 2014, 08:45 PM
F106DeltaDart's Avatar
United States, AZ, Prescott
Joined Jan 2011
You might want to read through this thread first: http://www.rcgroups.com/forums/showt...298826&page=97 It has lots of good info on the airplane. Although I can't answer your questions (I don't own one) the guys there should be able to help.
F106DeltaDart is online now Find More Posts by F106DeltaDart
Build Log Banana Hobby / LX Twin 70mm F-4 Phantom II Build Thread xplaneguy Foamy EDFs 220 Today 01:44 PM
Mini-Review LX F-22 Twin 70mm ACESand8s Foamy EDFs 64 May 18, 2014 03:02 PM
Discussion Banana hobby (lx) F-18 twin 70mm Bpitts Foamy EDFs 1 Jun 19, 2012 12:31 AM
Build Log LX's Twin 70mm TV, Afterburner Lights, F-22 EXTREME SETUP SkylineFlyer Foamy EDFs 100 Mar 06, 2011 03:14 AM
