Old Mar 26, 2002, 12:52 PM
poobs is offline
Find More Posts by poobs
poobs's Avatar
oakdale, ny, usa
Joined Aug 2000
Goldmine G4046 motor for EDF unit?
I ordered two rotors used on GWS 50 ducted fan units.
I have some of the litle G4046 motors. These are fairly high KV surplus motors.
My intenetions are to use the fans and motors with a home made housing to make a ducted fan unit.
These units will hopefully power a Wal Mart foam glider.
Should the housing be very close to the rotor blades?
How about hosing shape - should it taper or neck down slightly to increase velocity at the outlet?
poobs is offline Find More Posts by poobs
Old Mar 26, 2002, 01:07 PM
GoEFlight is offline
Find More Posts by GoEFlight
AeroMicro
GoEFlight's Avatar
Santa Clara, CA
Joined Sep 2001
Hello Poobs:
The following drawing may help.
http://www.aeromicro.com/images/Fan-2.jpg
GoEFlight is offline Find More Posts by GoEFlight
Old Mar 26, 2002, 02:52 PM
JasonJ is offline
Find More Posts by JasonJ
Dude, where's My Plane?
JasonJ's Avatar
Green Lane PA USA
Joined Mar 2001
the tips on a standard EDF should be VERY close, like 1mm close.
The shrouds normaly do not taper as they usally do not go far enough back to clear the motor housing.
The GWS is considered more of a shrouded prop, so tip clearance is not as critical, I have herd the GWS prop makes as much thrust outside the shroud as it dose inside, I have also herd the EDF 50 dose not like a decreased tailcone. But now you plan to spin the fan up alot faster than stock so EDF theory may start to come into play.
I would just experiment with a short duct 100% Fan area with it frist and see if you can find any more thrust from there.
JasonJ is offline Find More Posts by JasonJ
Old Mar 27, 2002, 11:04 AM
poobs is offline
poobs's Avatar
oakdale, ny, usa
Joined Aug 2000
Thanks guys.
I can't wait till I get the stuff in the mail
Old Mar 27, 2002, 11:07 AM
poobs is offline
poobs's Avatar
oakdale, ny, usa
Joined Aug 2000
GoEFlight
Is that a drawing of a stock unit?
I can see how the radious end would help airflow into the inlet.
I guess the exit cone helps smooth out the vortix caused by the outlet swirl of the air (?)
lehner motor for EDF dave morris Power Systems 3 Jan 08, 2006 04:23 PM
HET 2w motor, What EDF unit?? macca Electric Ducted Fan Jet Talk 2 Oct 11, 2005 03:25 PM
Feigao motor for EDF-40 indoorff Electric Ducted Fan Jet Talk 23 Apr 24, 2005 11:48 PM
Question Maxcim Brushless Motor For EDF WillowPtarmigan Electric Ducted Fan Jet Talk 3 Nov 07, 2003 07:39 AM
Brushless Motor For EDF? WillowPtarmigan Electric Ducted Fan Jet Talk 5 Aug 20, 2003 01:06 PM
