Old Jun 10, 2015, 10:29 PM
Hoot is offline
Find More Posts by Hoot
United States, TX, Houston
Joined May 2003
Quantity of butyrate dope to buy?
I'm building a Goldberg Falcon 56 that the will be covered with silk span and butyrate dope from Brodak. I haven't doped a plane in almost forty years. With average doping skills, how much dope should I buy? How about thinner and brush cleaner? Can I buy brush cleaner to clean the butyrate from the brushes at Home Depot? What do I buy, lacquer thinner, mineral spirits, etc.? Any painting tips ?
Thanks in advance,
S Gibson
Houston, TX
Hoot is offline Find More Posts by Hoot
Old Jun 11, 2015, 07:57 AM
AndyKunz is offline
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
We always bought in quart cans, and they usually only lasted two years. We did lots of building 8 ounces should do you fine.
Get a quart of acetone from the hardware department.
Use thin (but not too thin!) coats. A thick coat doesn't dry as nicely, will be uneven, etc. Two thin coats are much better.
Use a good brush if you're brushing it!
And if you want the best help, check out the C/L places like Stuka Stunt Works www.clstunt.com because C/L flyers are big on dope finishes and can tell you all the ins and outs.
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old Jun 12, 2015, 02:55 AM
epoxyearl is offline
Find More Posts by epoxyearl
Bellanca Kruesmaster
epoxyearl's Avatar
United States, MD, Elkton
Joined Oct 2011
I use a 1/2 'n 1/2 mix when sealing the pores, being careful to put on 'dry' coats, so it doesn't puddle inside the covering.
The last 'good' camel hair brush I bought was nearly $27 for a 1 incher !- but it does 'flow' the paint nicely.
I find the pints of dope cost nearly as much as the quarts do, so I opt for the larger size...Acetone, as Andy says, works fine as a thinner / cleaner.I have some 50 year old "Cub" butyrate,directly from Lock Haven.
I stopped there to get blue prints for the J-3 stripe, and an employee donated a quart to my project.
Does this old heart good to see a 'doper'......
epoxyearl is offline Find More Posts by epoxyearl
Latest blog entry: "Everything OLD is New...
Discussion Butyrate vs Nitrate dope Killionaire Free Flight 9 Jun 03, 2014 01:51 PM
Discussion Where To Buy Butyrate Colored Dope Nicksbbq Balsa Builders 24 Nov 14, 2013 10:36 AM
Discussion Butyrate dope revisited east6008 Vintage & Old-Timer Designs 12 Oct 08, 2010 04:25 PM
For Sale New SIG Butyrate Dope/sealer/thinner Twmaster Aircraft - Electric - Airplanes (FS/W) 0 Sep 25, 2005 03:30 PM
K&B Clear Butyrate Dope Twostroker Aircraft - Fuel - Airplanes (FS/W) 7 Dec 12, 2003 09:02 AM
