Old Feb 01, 2004, 07:53 PM
jcosta is offline
Find More Posts by jcosta
SlopeHead
jcosta's Avatar
Lisboa, Portugal
Joined Jan 2004
pico stick f (fokker) with 280 dd good for indoor?
I am interested in starting in indoor flying. I currently have a Pico Stick F (Fokker) 280, which comes with the GWS 280 direct drive motor.
(not built yet, still waiting for receiver).
Is it suitable for indoor flying or should I get an IPS motor ( I can use either as the plane is the same, what changes is the motor mount)?
jcosta is offline Find More Posts by jcosta
Old Feb 02, 2004, 09:28 AM
Tim Wolff is online now
Find More Posts by Tim Wolff
Gravity is a harsh mistress.
Tim Wolff's Avatar
United States, MI, Temperance
Joined Sep 2002
There is a Pico Stik F on IPS and Li-Polys at the local indoor sessions I attend. Flies great in a 2 basketball court sized gym. Your wing loading will increase with the heavier motor/battery combo with the 280. The plane is going to fly faster too. I'd go with the IPS drive for indoor.
Tim Wolff is online now Find More Posts by Tim Wolff
Old Feb 02, 2004, 12:02 PM
Jgardner is offline
Find More Posts by Jgardner
Fanfold abuser
Jgardner's Avatar
Rochester Monroe Cty, New York, United States
Joined Aug 2002
Wing loading
You can calculate the wing loading if it is not given in the kit. For a two court indoor venue I would think you would not want to be much over four oz/sq. ft.
If you can come in at about 7 oz. you should be at about 4 oz/sq ft. So, if you can make up for the heavy motor with lipolies, you may be good to go.
Jgardner is offline Find More Posts by Jgardner
Old Feb 02, 2004, 01:58 PM
jcosta is offline
SlopeHead
jcosta's Avatar
Lisboa, Portugal
Joined Jan 2004
Re: Wing loading
Wing loading is 4.25 Oz/sq ft and weight should come about 7.06 Oz
Old Feb 02, 2004, 04:07 PM
Jgardner is offline
Fanfold abuser
Jgardner's Avatar
Joined Aug 2002
That should work
Folks at our fly-in often fly Tiger Moths (GWS) with about that wing loading. It sounds like yours should be ok.
Indoors, lighter wing loading is almost always better from my perspective. The lighter combo of smaller lipolies and the IPS might be good for the future.
Good luck.
Old Feb 18, 2004, 11:59 AM
jcosta is offline
SlopeHead
jcosta's Avatar
Lisboa, Portugal
Joined Jan 2004
After trying it out, I gave up on the DD 280 and have purchased an IPS B with 11x4.7 prop.
It flies much better!!!
And the motor mount for the 280 sucks big time! The stick is much simpler...
I'll find another home for the 280... But not a GWS one.
Old Feb 18, 2004, 01:22 PM
Joo Cosme is offline
Find More Posts by Joo Cosme
France
Joined Jan 2004
bom voo JCosta de Joo!!!!
Joo Cosme is offline Find More Posts by Joo Cosme
Discussion 280 Motor Version for PICO-STICK-F rcflyertim GWS (Grand Wing Servo) 40 Sep 11, 2006 09:27 PM
Any problems with a HFS-04MG in a Pico Stick F? asennad Parkflyers 1 Mar 31, 2004 01:35 PM
Pico Stick F with 280 DD suitable for indoor? jcosta GWS (Grand Wing Servo) 9 Feb 18, 2004 12:20 PM
Pico-Stick-F with Ailerons realglow Parkflyers 6 Jun 11, 2001 12:29 AM
Pico-Stick-F with 280 Motor? realglow Parkflyers 1 Jun 06, 2001 11:19 PM
