Old Dec 06, 2012, 07:09 PM
Captain50 is offline
Find More Posts by Captain50
Joined Oct 2012
PZ Ultra-Micro Spitfire Aileron Hinges
I just picked up a Parkzone Ultra-Micro Spitfire. I noticed a few of the attached foam aileron hinges arent attached. There is tape on the underside of the aileron but Im curious if I should return it or if that thin foam hing eventually tears anyways.
If so, should I put a small tab of tape on the topside of the hinge as well as the bottom?
Captain50 is offline Find More Posts by Captain50
Old Dec 07, 2012, 03:06 PM
Tommy21781xxx is offline
Find More Posts by Tommy21781xxx
United States, MI, Waterford Township
Joined Aug 2012
If your gonna add anything, I would add blenderm. Its a hinging tape. I would prob just take it back.
Tommy21781xxx is offline Find More Posts by Tommy21781xxx
Old Dec 07, 2012, 06:49 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
The AS3X can work the foam and tape hinges pretty good and the duty cycles eventually will cause them to fail.
I replace the tape with 3.5" floppy disk mylar strips, slotted into the foam and held in place with UHU por. It takes a little longer than tape, but is much more solid and you never have to worry about it again.
UNGN is offline Find More Posts by UNGN
Discussion PZ Ultra Micro Trojan Aileron Problem JayhawkJake Micro Ready-to-Fly 9 Jun 19, 2015 09:58 PM
Help! PZ Ultra Micro T-28 Ailerons Not Working Nomadtech Beginner Training Area (Aircraft-Electric) 12 Aug 13, 2012 08:49 AM
Help! PZ Ultra Micro T-28 Ailerons Not Working Nomadtech Scratchbuilt Indoor and Micro Models 11 Aug 04, 2012 01:52 PM
For Sale PZ Ultra Micro P-51 Mustang TuMadre Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Apr 05, 2012 08:17 PM
Discussion How does PZ Ultra Micro P-51D compare to PZ T-28D as first aileron trainer? demuddy Beginner Training Area (Aircraft-Electric) 23 Feb 26, 2010 04:21 PM
