Old Oct 22, 2012, 04:13 PM
jim2wright is offline
Find More Posts by jim2wright
Joined Mar 2012
prop direction for 4 engine ??
Hi,
Building my first 4 engine after successful build of a big twin model. Have been thinking about prop rotation directions. Am thinking props counter rotating next to each other. That way air between the adjacent nacelles is moving same direction (tangent to prop arc). Less likely to FOD the prop next to it if there's a problem? Does it matter much?
Thoughts?
Thanks in advance.
jim2wright is offline Find More Posts by jim2wright
Old Oct 22, 2012, 05:50 PM
Doug Bartley is offline
Find More Posts by Doug Bartley
Doug Bartley's Avatar
Canada, ON, Owen Sound
Joined Oct 2008
JMHO, two outboard props turning CCW (normal) with two inboards CW. I assume this will be electric and reversed props available. Doug
Doug Bartley is offline Find More Posts by Doug Bartley
Old Oct 22, 2012, 05:56 PM
pda4you is offline
Find More Posts by pda4you
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
Thoughts?
Nope it does not make much difference at all. Just as in full scale they typically turn the same direction - all of them.
I think you will be hard pressed to tell any difference. And it is hard to find reverse props anyway.
Old Oct 22, 2012, 06:31 PM
Zootster is online now
Find More Posts by Zootster
Joined Jul 2007
Circular direction......
Zootster is online now Find More Posts by Zootster
Old Oct 23, 2012, 06:47 AM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Plus all sucking and blowing the same way
I have flown twins and fours, with counter rotating props and later changing them to all the same way. There was no noticeable difference in flight or trim, so it's more a case of how you fancy setting up your plane.
Just get the prop rpm within say 300 rpm of each other, even that is not all that important either as things can change some in the air as the props unload. Obviously you don't want them way off.
eflightray is offline Find More Posts by eflightray
Old Oct 23, 2012, 08:43 AM
pda4you is offline
pda4you's Avatar
Joined May 2002
Funny you should mention that. When I started playing with differential thrust (for Yaw control) it was astonished at how far off you needed to be before one motor would provide sufficient yaw. On the OV-10 with twin large vertical stabs and rudders it was like 70% power from one motor!
It certainly differs model to model but now I start with about 30% differential and move up from there. Amazing.
For Sale Gemfan Nylon Props 4 props for $4 (2-CW and 2-CCW) danphillips Aircraft - Electric - Multirotor (FS/W) 8 Aug 31, 2012 08:55 AM
For Sale Gemfan Nylon Props $4 for a set of 4 props (2-CW and 2-CCW) danphillips Aircraft - Electric - Multirotor (FS/W) 10 Aug 27, 2012 03:53 AM
Discussion Motors turning in directions on 4 engine models, it this true? Concordefan RC Airliners (Commercial, Cargo, Troop Carrier) 13 Jun 14, 2012 04:55 PM
New Product Cox 4.5 x 4 Competition Props now available for .049 engines xenalook 1/2A Planes 9 Apr 28, 2011 03:40 AM
Discussion Free Direct drive props for 4,6,7mm motors Bob Blackburn Scratchbuilt Indoor and Micro Models 10 Dec 16, 2006 05:33 PM
