Old Sep 27, 2012, 10:13 AM
Batmanwpg is online now
Find More Posts by Batmanwpg
Boar? I'm a Thermal Pig!
Batmanwpg's Avatar
Winnipeg, Canada
Joined Aug 2004
Question
Pull pull line?
I'm doing my first F3P and it uses pull-pull on the stab and rudder. What are you guys using for the lines? What's the best way to set them up?
Barrie
Batmanwpg is online now Find More Posts by Batmanwpg
Old Sep 27, 2012, 04:37 PM
Free is offline
Find More Posts by Free
"Free" in Christ! #F3P
Free's Avatar
United States, CA, SF
Joined Jan 2012
This is how I do my pull pull. But a lot of people use Kevlar thread.
http://flightpass.higherplaneproduct...p?g2_itemId=55
Go to the bottom of the page!
Free
Free is offline Find More Posts by Free
Old Sep 27, 2012, 04:49 PM
Not Free is offline
Find More Posts by Not Free
Foamies for life! #f3p
Not Free's Avatar
Joined Sep 2011
I am presantly using Kevlar thread, but Fishing Line works quite well!!
Not Free
Not Free is offline Find More Posts by Not Free
Old Sep 27, 2012, 05:01 PM
Batmanwpg's Avatar
Winnipeg, Canada
Joined Aug 2004
Thanks. Easy enough. I'm just about done painting it. I will post pics soon.
Old Sep 27, 2012, 05:10 PM
Free is offline
Free's Avatar
Joined Jan 2012
Great!
Free
Old Sep 27, 2012, 09:04 PM
Batmanwpg's Avatar
Winnipeg, Canada
Joined Aug 2004
Mercury F3P
This is an older design Called the Mercury. I wanted a simpler design for my first F3P. Paint job is finished and assembly will start soon.
Old Oct 01, 2012, 10:00 PM
Batmanwpg's Avatar
Winnipeg, Canada
Joined Aug 2004
Framed up
She's all framed up but without wheels. Electronics to follow also.
Old Oct 05, 2012, 08:20 PM
Batmanwpg's Avatar
Winnipeg, Canada
Joined Aug 2004
I scrambled like crazy to get it finished today because our first indoor session is tonight. Weight is average I guess for a plane of this build at 152 grams with a 2S 450 mah battery. I will try a 360 later but the 450 is for initial tests and balance. The wheels aren't permanent either. I will turn some lighter foam ones soon.
Old Oct 06, 2012, 04:25 AM
rgj is offline
rgj
Find More Posts by rgj
rgj
Joined Dec 2010
Have you milled the plane? to get it light its a hugh advantage to mill the plane you can easy get 15 gr off the plane with milling and that can let you go with a lighter engine and smaller battery ..so if you can loos 15 gr on the plane and some few on the enigen and maybe 5 on the battery you will end up at maybe 125 the rest has to be saved on the build ..less glue and paint maybe? I have used paint that are for airbrushing (waterbased) and airbrush this only add maybe 1 gr on the plane , but I dont get a finish as nice as you (the colors are not so clear and strong).
But I think you are in the right direction with this plane it looks right so enjoy the plane and start planning on a new build (maybe for next year).
The real advantage for a light plane is the speed both in the up and down lines and this will give you more time to get through the manuevers.
But you plane looks similar to one I bulid last year (found drawings on the net some place) flew great but it was to heavy for the gym that we fly in som its resting in my workshop.
rgj is offline Find More Posts by rgj
Old Oct 06, 2012, 11:13 PM
Batmanwpg's Avatar
Winnipeg, Canada
Joined Aug 2004
rgi
I haven't milled the plane for several reasons. When I build a new category of plane I always like to build a simple version of it first and find out it's flying characteristics and any weaknesses the design might have. Also where I fly there is no specific time to fly just F3P and many types are flying at the same time. Many micro BNF's and larger fun type airplanes. Chances of a mid-air are good. I happened to have one with the first flight with the Mercury with a micro BNF. Luckily the other guy took the worst of it and only small amount of damage to one of my SFG on the wing. It was fixed in a few minutes and flying again. A milled airplane in that environment won't last long. I will build a milled airplane at some point. Building light is not new to me as I built competition indoor and outdoor Free Flight models for many years. Anyways it flys well but was a bit tail heavy. I will change things to fix the problem and get it flying better.
Old Oct 06, 2012, 11:47 PM
rgj is offline
rgj
rgj
Joined Dec 2010
we are about 10 guys meeting and it only F3p style flying in the gym we fly alone and ca 4 min each ...it nice and safe and then you can use those extra hours building and not getting eaten up by others! so I see you issue
pull-pull: slack in non-pulling line steve crewdog The Builders Workshop 4 May 30, 2005 11:47 PM
