Espritmodel.com Heli Air
Old Yesterday, 07:29 PM
Zé Povinho's Avatar
Joined Feb 2005
Economical gloves for DLG
Good evening.
When learning to fly DLG with the Sidewinder II two years ago, I noted that the launch peg (not blade) caused blisters in my fingers and gave me a very poor grip. The Mystress tended to pull away from me before I finished the full circle for launching.
In addition, the sweat in my hands caused the fiberglass at the wingtip to fall off, and I had to replace that using foam safe CA glue and fiberglass cloth left over from my very first DLG (a DL-50).
Then I found the solution to all these problems-poor grip, blisters, and fiberglass falling off the wingtips on the side of the throwing peg/blade. Just wanted to post it here.
I play handbells in a bell choir (in case you wish to hear what a bell choir looks like and sounds like, just go to Youtube and perform a search for handbells. You will get hundreds of examples).
We wear gloves especially made for handbell ringing-just google "handbell gloves" and you will be shown sites where you can buy them. They are made of cotton and are washable. We use the ones with the raised dots for improved grip and for preventing palm sweat from ruining the bell polish-these dots are the key for DLG.
For DLG, if you want to try these gloves, make sure you get the ones with the raised dots (they are offered in the no dots version, too) AND the velcro strap for your wrist. The strap will prevent the glove from falling off when you perform the DLG launch procedure.
I wear only the right hand glove (my throwing hand), leaving the other without it. The glove in no way gets in the way of handling the radio sticks and switches.
This is not an advertisement. It is just posting a possible solution if any of you are encountering similar problems and are looking for an inexpensive yet effective (for me) solution. Best of all-these gloves cost less than 8 dollars and can fit perfectly inside a TX case.
Zé Povinho is offline Find More Posts by Zé Povinho
Old Yesterday, 08:06 PM
C-c-c-custom!
United States, NM, Albuquerque
Joined Nov 2011
I've seen people using similar gloves. I prefer not to wear them as I tend to hook the launch if I do. Eventually some nice calluses build up and I stop having issues.
closedloop is offline Find More Posts by closedloop
Old Yesterday, 08:13 PM
New Zealand, Marlborough, Hawkesbury
Joined May 2010
Another option which works for me is to wrap a couple of turns of masking tape or even sellotape around the ends of my index and middle fingers on my throwing hand. I found this both prevents abrasion/blistering of my fingers and also allows the blade to slip off my fingers more cleanly at release. I don't seem to hook my throws as much using this simple and cheap solution.
Maybe I am just too miserly and should go and buy some gloves!
fishbed is offline Find More Posts by fishbed
Old Yesterday, 08:37 PM
Congress, AZ
Joined Sep 2001
Proper contour on the throwing peg really helps. See the SGII plans on CharlesRiverRC.
Gary
GaryO is online now Find More Posts by GaryO
Old Yesterday, 09:25 PM
Team Hong Kong F3K
ThomasLee's Avatar
Hong Kong
Joined Sep 2010
I used to wear gloves too and they helped a lot. With newer moulded blades now I'm back to nude
ThomasLee is offline Find More Posts by ThomasLee
Latest blog entry: Neos Layups
Old Yesterday, 10:59 PM
Will fly for food
davidjensen's Avatar
Bellevue WA,
Joined Dec 2003
I've gotten used to gloves and at the DLG Clinic I went nude and was releasing early quite often. Golf gloves don't last very long and baseball gloves are just too small for my hands. I need to find something else.
davidjensen is online now Find More Posts by davidjensen
Latest blog entry: Scale and Aerotowing
Old Yesterday, 11:07 PM
In F3J size does matter!
roydor's Avatar
Israel
Joined Nov 2006
No gloves for me, if the peg is shaped properly there is no need for them
roydor is offline Find More Posts by roydor
Old Today, 04:08 AM
DS Addict
ALEX HEWSON's Avatar
Christchurch, New Zealand
Joined Jul 2005
This was the reason for me making the Curved Offset T-blades
I now don't get blisters or any fingertip soreness
ALEX HEWSON is offline Find More Posts by ALEX HEWSON
Old Today, 11:25 AM
Will fly for food
Bellevue WA,
Joined Dec 2003
I find I can get a better release with a glove than without. I just installed the Light Curved Offset Blade in my new Neos. They are the best.
Old Today, 01:00 PM
WAA-08 THANK FRANK!
JimNM's Avatar
Las Cruces, New Mexico, United States
Joined Jun 2002
I use talcum powder (a little goes a looong way!) to keep my fingers dry and slippery. A little bit of moisture makes the cf peg stick to my fingers.
I also use the middle and ring finger hold, which I call the "SPOCK" launch vs. the pointer and middle finger hold, which I call the "PEACE SIGN" launch. My ring finger is closer to the length of the middle finger than my pointer finger is, and I have better feedback from the palm of my hand, which allows me to better feel the launch angle. There is less offset between the center of my arm/wrist and the center of the wing which I belive results in less imparted twisiting motion during the spin.
Fly well,
JimNM
JimNM is offline Find More Posts by JimNM
Old Today, 08:41 PM
DS Addict
Joined Jul 2005
Makes sense, Jim. I must try that one day
Cool A blast from the past (robbe economic) might Radios 0 Jan 24, 2013 09:17 AM
Wanted Turnigy transmitter glove chessmaster Aircraft - General - Miscellaneous (FS/W) 0 Jan 02, 2013 07:01 PM
Discussion DLG Gloves haggy38 Hand Launch 23 Sep 08, 2012 10:14 PM
Discussion Winter gloves for DLG Fly2High Hand Launch 17 Jan 04, 2008 06:38 PM
